-   -   rear sway bar bushing help (http://forums.pelicanparts.com/porsche-911-technical-forum/1116051-rear-sway-bar-bushing-help.html)
47silver 04-02-2022 03:06 PM
i do not know which sway bar bushing to purchase for my 1975 911S targa. Itt is an early targa
i bought 4-91134379203 but they are way too big, have not clue why I bought them as the pet lists 2 types
91133379302
91133379302
the originals look like 91133379302 but they both say 18mm which i have
any clue as to which ones to purchase?
mikesarge 04-02-2022 04:01 PM
Your best bet is going to be to measure the bar with a caliper, and then order by size rather than number.
Solamar 04-02-2022 07:23 PM
Yep. Somehow the sway bar bushings have been mislabeled and are frequently the wrong size.
For example, the correct part number for a SC bushing is too small and will bind. The 930 pn is correct for the SC.
Buy a few and return what doesn't fit?
47silver 04-03-2022 11:38 AM
thanks for the responses, will post my findings
chrismorse 04-03-2022 06:06 PM
check the bar mounts, failure fairly common
"While you are in there", carefully check the bar mounting brackets attachment to the chassis. My dad's 74 was driven very conservatively, yet at some point one of the mounts failed and his shop just removed the bar.
When i inherited the car, i installed the Wevo mounts, which required the bigger, later style bushings and attachment straps.
good luck,
chris
AlKidd 04-03-2022 06:25 PM
FWIW, my car has Weltmeister sway bars front and rear. The bushings were missing when I got the car. I removed the end links and brought them to a local machine shop who turned me new ones out of dense polymer material. Might have been Delrin but he wasnt sure what was in his junk drawer. Was $40 with a beer discount and conversation about cars. Might save you a bunch of ordering and waiting. Guy spun them on the lathe in under an hour.
47silver 04-03-2022 09:09 PM
Thanks . Ill check connections
47silver 04-06-2022 03:04 PM
sway bar and end link bushing part 911 333 793 02 fits my 1975 911s. The bar is 18mm.
