Help- Oil Leak between head and cam tower
Good day all: I did a reseal on my 78 3.0 last year and after completion I had a small but annoying oil leak oncoming off the front edge of the cam tower. ( which of course drips on the exhaust).
I finally found the source- there is a drip off No 3 head to cam tower joint. It is right at the bottom , and is very small but it is there. This joint is sealed by the Locktite 574 and I am the one that did this job and obviously I did not get this 100% right. The question: has anyone ever tried to seal this leak without disassembling the engine ? Any advice appreciated . Thanks Karl |
Could be a rocker shaft....
Did I ever say I hate 574?
Under the radar
What is your recommendation?
Hi John: yes I checked the rocker shafts first. I redid these last year and added the rsr seals . They all look tight, and have not moved . I would appreciate your recommendation if you have any suggestions. Btw , have you had trouble with 574 before and what do you use instead ? Thanks Karl
Leak
Small leaks, sooner or later, become bigger leaks...
If you decide to disassemble the engine, do a top end overhaul while you are there... |
https://nineelevenheaven-wordpress-com.translate.goog/abdichten-der-kipphebelschafte/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
(Translated via Google)
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
I have done this on a couple of cars with less than perfect shaft sealing, and it has so far held up well. The fact it is curil T also means when it needs to come out, it can still be easily cleaned off too.
Always learning. www.aircooledporsches.com.au |
Under the radar
Porsche, in it's manual says to use Teroson Atmosit, which sounds like Yamaha bond. Bruce Anderson says use RTV, (yeah I know). Wayne, in his book says use 574. In the Complete Engine Sealant thread Threebond 1184 is recommended. I have heard of mechanics using Curl t, btw. From my research; Yamaha bond = Threebond 1184 a synthetic rubber sealant? Threebond 1211 = RTV a silicone based sealant? What say the experts?
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 04-05-2022 at 12:36 PM.. |
Gray Dirko for me. Case halves, heads to towers, 915 case sections.
574 is supposed to be applied very thin, like with a tiny roller, and the sections need to be tightened up quickly, before the stuff sets up when deprived of air, otherwise "shimming" can result, as described in the 574 PDF. That's when the stuff doesn't get squeezed out and sets up before tightening. Lots of folks tighten the case through bolts first, then do the perimeter nuts. Big mistake. Often the cause of the dreaded leak between the case and #8 main bearing, when shimming happened and the case halves didn't get pulled together properly before the stuff set up. Use it at your own risk. I just spent a lot of time scraping thick deposits of 574 off the case halves of a 3.0 I'm building now. My first personal experience with shimming was a 77 930 engine i did about 30 years ago. #8 bearing/case leak. Total teardown to fix and lots of wasted time. Done with that stuff.
i never had a problem since i do the case as you said John...but there is always new stuff which can be use i`ll give it a try on my next 930 engine next week.I know you told me once but i cannot find exactly the Gray Dirko number....would you share
thanx ivan could it be this one? https://eshop.svetluska.cz/fotografie/max/tesnici-tmel-dirko-70ml-seda-elring-el036-164-3018820.jpg
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 04-05-2022 at 02:26 PM.. |
That's it, and also the 510-030, 575 degrees.
I have had excellent results using Dow Corning 730 sealant. Either the added benefit of being easy to remove if you have to disassemble again
Gotta be fast with 730 as it skins over real quick, unlike dirko.
This seems like a much better approach. I’ve never used 574 but I’ve done a lot of reading on it.
Seems like a total PITA due to the quick set time. I used Hondabond for the first time the other week and I was surprised at how quickly it skinned up. I ended up dismantling my CV joints and scraping it all off. It went better the second time around since I knew what I was up against. I couldn’t imagine trying to get the case halves buttoned up before the 574 starts to set. I know many people do it successfully but, given the above information I’ll use Dirko.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
[QUOTE=pkabush;11657088]This seems like a much better approach. I’ve never used 574 but I’ve done a lot of reading on it.
Seems like a total PITA due to the quick set time. Yes, it is all about practice .I do the outside 1st, after the case bolts all done about 20-30...minutes..never had problem, this one is done at home in the kitchen .Also the 574 must be only used on one side of the engine case...i do not use roller just spatula for sorting pharmacy pills here https://www.youtube.com/watch?v=IandhtwG5no&t=377s https://www.youtube.com/watch?v=2S0OuXyfIMU&t=5s
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 04-06-2022 at 12:12 AM.. |
New-ish 911SC Targa Owner
is Dirko gray essentially RTV silicone?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
it did indeed turn out to be that rocker shaft end that faces the chain case..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Yes. But don't be afraid of modern RTV's. They're successfully used on MILLIONS of vehicles that don't leak. Like John, I would never assemble a Porsche engine with 574. There are far too many better sealants available now.
Three bond product comparison. https://threebond.com/wp-content/uploads/Products-Guide_ver6-LOCAL.pdf |
i actually used 3 bond on one side of my engine and 574 on the other. People seem to forget 574 was used successfully for decades. Just because there is better out there doesnt mean it is bad.
My car is dry.
the only thing you need to watch for on 574 is the dates...if the orange is expired it will create inside sand like a stuff,that is totally PITA to use
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
