-   -   Confirming that a Late model SC ALTN is compatible with 3.2? (http://forums.pelicanparts.com/porsche-911-technical-forum/1116533-confirming-late-model-sc-altn-compatible-3-2-a.html)
Hotshot 04-09-2022 09:49 AM
I think my new Valeo ATLN / internal VR is bad. I can’t shake this over voltage problem. Randomly still fluctuation with Revs and then the fun starts. Not as high as it was but 15.V is not where I want to be. Lights really get it going..
I want to use a buddies SC ALTN with internal VR as a final test.
Batt is good
Replaced , isolated or serviced every
Motor in the car.
Grounds are checked.
Yet the Voltage wil just go off. Fried my blower resistor in the process.
Nothing I can think of will cause over voltage except a Bad cell,
ALTN, VR, or a motor..
mysocal911 04-09-2022 09:56 AM
Batt is good
Motor in the car.
Different alt for SC vs 911 3.2, e.g. SC 6mm studs vs 5 mm for 3.2
Hotshot 04-09-2022 11:16 AM
Damn.. I have 3 SC ALTNs.
Voltage Reg same?
john walker's workshop 04-09-2022 01:05 PM
If you can find a spacer to make up the difference in height it will work. They're out there.
Hotshot 04-09-2022 01:44 PM
Good point. I can return my Velao under warranty so I’ll do that.
Is the VR the same? If so I can pop one off and into the other. Just don’t wannna pull it all apart.
Hotshot 04-09-2022 02:26 PM
