Send a message via Skype™ to Einar Irgens
Searching for welch plugs for (Zenith) carbs
I had to remove six of these welch plugs (don't ask why) on my Zenith TIN 40s.
Does anyone know where new ones can be obtained?
Einar
Einar Irgens
1973 911E targa
Old 04-04-2022, 12:51 PM
rsscotty's Avatar
Check with Paul @ Performance Oriented.......he does Weber restoration but might be able to help you out.
Old 04-04-2022, 01:16 PM
1QuickS's Avatar
Those are lead plugs, which were spherical. I used to cast my own using a mold I made but have since found that 0.177 caliber air rifle lead pellets work well. Drive the pellet into the opening with a small ball peen hammer then use a punch with its end re-shaped to be spherical to punch the lead home and trim off the excess lead.
Lead shot for shotguns is NLA in an appropriate size due to environmental effects of lead falling onto fields.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 04-04-2022, 03:02 PM
Thank you for the reply (forgot all about the thread, but from now I subscribe). It could be hard finding a led bullet, but I'll try. Until then, is it strictly necessary to seal off the holes? They will be shut by the gasket between the carb and intake manifold anyway.
Einar
Einar Irgens
1973 911E targa
Old 04-06-2022, 03:29 AM
ahead of the curve
Jeff Burger's Avatar
many years ago I used the split round lead weights used for fishing. I stopped fishing ages ago (and working on carbs) so they maybe NLA like the shotgun pellets mentioned above.
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 04-07-2022, 09:01 AM
A colleague at work has some vintage airgun ammo at home, so I'll be all right, thank you.
Old 04-07-2022, 10:13 AM
Air gun ammo worked nicely.
Thanks again, Mr Abbott!
Einar Irgens
1973 911E targa
Old 04-11-2022, 02:08 PM
1QuickS's Avatar
One is glad to be of service.
Paul Abbott
Old 04-11-2022, 03:21 PM
