-   -   Does anyone know where this piston is from? (http://forums.pelicanparts.com/porsche-911-technical-forum/1116573-does-anyone-know-where-piston.html)
psychoideas 04-09-2022 10:44 PM
Hello,
Years ago while collecting Porsche 'Stuff' i bought this piston.
I just found it again after searching for another part and was wondering if anyone know what it may have been destined for before it was turned into art?
It's approximately 93mm in diameter and looks to have a '5' hand engrave inside one of the skirts and a crudely drawn '0' inside the other shirt.
Anyway just curious.
Frank
http://forums.pelicanparts.com/uploa...1649569352.jpg
faapgar 04-10-2022 04:08 AM
piston
For a non-hemi 4 valve head.
ian c2 04-10-2022 07:10 AM
Porsche 959 .
Official porsche part , to be used as a desk ornament or ashtray or something :rolleyes:
Here’s mine .
http://forums.pelicanparts.com/uploa...1649599833.jpg
pampadori 04-10-2022 12:11 PM
Assuming it was originally a piston cast for actual use, what is with the little groove between the two compression ring grooves?
psychoideas 04-10-2022 03:43 PM
Originally Posted by ian c2 (Post 11660877)
Porsche 959 .
Here’s mine .
Interesting, do you know any more of their origins? Was it really a piston that the 959 used?
So was it a promotions type thing sold at the dealerships as 'Art'???
ian c2 04-10-2022 08:27 PM
I presume the groove was put in there to differentiate it from a QA approved part for install .
These where genuine 959 pistons ( carry over from 935 962 ) , and came from dealerships .
Not sure if they where sold , or giving as gifts .
If you Google it , you’ll find an interesting Sotheby’s auction result from a couple of years ago ….
The latest version porsche has available is a 992 piston phone charger .
https://www.porscheleeds.co.uk/about-us/2021/911-wireless-charging-piston/911%20wireless%20charging%20piston~leeds~~newsmode l~en
https://www.porscheperth.co.uk/about-us/2021/911chargingpiston/porsche%20911%20wireless%20charging%20piston~perth ~~newsmodel~en
BURN-BROS 04-10-2022 09:40 PM
It’s an “accumulator groove” . Used to gather oil between the two rings to promote lubrication.
psychoideas 04-10-2022 09:52 PM
Interesting. Mine has some hand engraving inside of the skirt. On closer inspection looks like an 'E' on one side and an 'O' on the other.
Jon B 04-11-2022 11:41 AM
Here's a Mahle 82mm TAG-Porsche Formula 1 piston.
It's from the same era, and of a similar design.
It was made in two pieces, then electron-beam welded together. This created a chamber into which oil was jetted.
The oil inlet is seen in the lower photo, with an outlet on the other side. I suspect yours is similar?
http://forums.pelicanparts.com/uploa...1649701041.jpg
http://forums.pelicanparts.com/uploa...1649701085.jpg
psychoideas 04-11-2022 12:50 PM
Interesting stuff. Thank you for the info. Mine is approx 93mm dia but I'll look for the extra holes in it when I get home.
Cheers
