Strange brake issue - firm pedal collapses
Car is a 1968 912 with 911SC front calipers, 912 rears and a 19mm dual-circuit master cylinder.
I have just fitted a new (ATE) master cylinder as I suspected the old one was failing. The system has been bled multiple times - I’ve put perhaps a gallon of fluid through the lines! I can get a very good, firm brake pedal, which holds. However, if I release pressure just a touch, the pedal slowly collapses (although it never reaches the floor). The way this translates in driving the car is that the brake pedal has initial normal, firm feel, but after three seconds or so it slowly gives way. I’m absolutely stumped - have never experienced anything like this, and I can’t visualize what’s happened here. Would love to hear from anyone with previous experience of this issue! James |
Senior Member
If a brake pedal works fine when you stab it, but will go to the floor if you press gently, then you have a master cylinder problem. The seals are letting fluid past them, when you press gently. They should seal instead. What happens when you stab the brakes is that you create enough pressure to force the seal against the piston, and if the force is maintained the seal is holding that pressure.
Or maybe those are not your symptoms?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Yes, that's absolutely what's going on.
Ugh. Brand new ATE part, too. Hopefully Pelican will be quick to replace it. And it's such a pleasure to lie under the car withe brake fluid running down your arms. Cannot wait to do it again ![]() Thanks for the help! James |
Racer
Or a broken hub….
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Before you remove a new master i would check all the lines to each wheel and their respective calipers. I had the exact same issue on a truck i owned, including buying a new master cylinder only to eventually finding a leak on one of the brake lines which would hold on initial brake pedal press but slowly leak after and have pedal go to floor.
Thanks. Should have mentioned - no fluid loss anywhere. Also checked every joint in the system.
