-   -   Help installing Tarett Camber Plates (http://forums.pelicanparts.com/porsche-911-technical-forum/1117117-help-installing-tarett-camber-plates.html)
vick 04-17-2022 07:32 PM
Hi gang - situation is the strut mount on a 1974 coupe with monoballs cracked, see pic. Heard a little rattle from the front end and couldn't find anything amiss, finally found this crack.
Plan is to swap the factory strut mounts for Tarett Camber Plates. Trying to work the struts down through the monoballs isn't working, just not enough travel to get the strut out. Advise to get the struts out? Will pulling the lock pin on the bottom get more clearance?
If anyone has installed the Taretts (which look exactly like the ones available from ER), any tips? They came from our host with no instructions.
Thanks in advance
http://forums.pelicanparts.com/uploa...1650248825.jpg
ed317 04-17-2022 08:12 PM
Ira at Tarett is super helpful, you can call him
Mahler9th 04-18-2022 09:43 AM
Ira is a great resource.
My car is a '75 but likely different from yours. When I installed these parts I disconnected the bottoms of the struts with the car up on jack stands.
Whenever I do this I consider replacing the wedge pin bolts.
vick 04-20-2022 01:18 PM
1 Attachment(s)
Thanks for the suggestion to call Tarret, makes sense. I got the old ones out and got the Tarrets in, wasn’t difficult after fiddling with it for a bit.
Keep an eye in the classifieds, will offer a good deal on this lightly used set that came out [emoji23]
Attachment 10627
donbecker1234 04-20-2022 01:43 PM
Attachment 10627
Just a heads up that those aren't stock plates.
jonesb930 04-20-2022 02:16 PM
looking at the close up they appear to be cast aluminum. I believe the Tarrets are made out of a solid billet. Way stronger. Does anyone have a guess on who made these?
I know the mono balls transfer a bit more energy into this area than the stock rubber.
pkabush 04-20-2022 04:27 PM
Interesting. They definitely do look to be cast. Stating the obvious here but, not a great choice.
I bought mine used and I don’t remember if they’re Tarrets but definitely milled from billet aluminum.
vick 04-20-2022 06:29 PM
Thanks Don, we were aware of that. This car did track time in a previous life and has lots of tweaked suspension bits as a result. These clearly didn’t age well
vick 04-20-2022 06:36 PM
They do appear to be cast. When I heard the initial rattle the crack was small and I didn’t find it. Drove a bit more and it opened up, easier to find then. The monoballs are definitely harsher than the original rubber bushings, couple that with pushing the car harder and I’m not surprised one of these didn’t age well. I’d love to know who made these but no markings aside from L & R
The Tarrets are a work of art in comparison. Got them in and loosely centered but I’ll need to get the car in for a proper alignment to do them justice
