Born to Lose, Live to Win
ramonesfreak's Avatar
fresh air blower on/off lever is tight - 1983
hi. turning the fresh air fan on is pretty easy. not much resistance. sliding the lever back to the left to shut it off is really a firm push. sometimes have to go in small distances. stop and then push some more. something aint right
is there a troubleshooting procedure to fix this? a point of lubrication?
1983 911sc
2025 Chevy Colorado ZR2
Old 04-29-2022, 12:25 PM
Just did a complete redo on my '86 M491 Cab. Fresh air fan motor quit. Easy disassembly. Tougher removal of squirrel cage fan from hub (used a soldering iron carefully to heat shaft), easy clean and resistor reset. The cable mechanism on my car uses one cable (top slide) to open/direct fresh air and then actuate three speed fan switch (controlled by resistor). When disconnecting cable link extend it all the way to right and clean and re-lube w/lithium grease. Work it back and forth several times/repeat until it operates smoothly. Use the Bentley manual for a direct play by play. By the by the little rings holding the housing together are a tough nut to remove and be careful not to break the plastic tips they bind together.
Go to Fresh air blower controls for more info
'86 Porsche 911 M491 Cab. Guards Red/Black. Sold '93
'86 Porsche 911 M491 Cab. Iris Blau Metallic // Turbo-Look Registry #4200
Old 04-30-2022, 12:53 PM
Thanks for the helpful info !
1983 911sc
Old 04-30-2022, 01:20 PM
