-   -   Refuses to idle 83 sc (http://forums.pelicanparts.com/porsche-911-technical-forum/1118112-refuses-idle-83-sc.html)
hughc 09-12-2022 02:58 PM
Thanks all. Time to close this thread.
The WUR, the CSV, TTS and all injectors were sent to boyt911sc and were all checked for proper functioning and adjusted as necessary (WUR).
Everything has been re-installed , the engine fired up straight away and has been running quite nicely since. So I should be out of the woods for now.
Thank you for the great work, Tony.
hughc
boyt911sc 09-15-2022 05:28 AM
Everything was OK except the WUR.......
hughc
Hugh,
All I did was recalibrate the WUR to spec because it was “out of calibration”. All the other CIS components you sent were tested and confirmed good. Good job.
Tony
