Thanks Ruben,
The pressure measurements indicate the WUR is OK but the cable from the panel that powers the WUR has a broken connection. You can jumper around the bad cable and get the WUR to operate normally. Hopefully the car will be fixed in the next day or two. Thanks for your help, Troy |
