-   -   911 3.2 What did I break? (http://forums.pelicanparts.com/porsche-911-technical-forum/1118490-911-3-2-what-did-i-break.html)
Marined 05-08-2022 05:41 PM
http://forums.pelicanparts.com/uploa...1652060127.jpg
I was changing the Decklid Shocks and snapped off the white plug with the brown wire. The wire has 698611-7 on it.
What is the name of the white plug and where on PP is a part to replace it?
Thank you,
Ed
mdwracer 05-08-2022 05:48 PM
It's the engine temp sensor. It goes to the #3 cylinder head.
wrxnofx 05-08-2022 05:49 PM
Pretty sure that’s the cylinder head temperature sensor (as opposed to the speed and reference sensors). You will want to pull out the metal plate that holds the connectors together and disconnect the sensor from the harness. If you’re lucky you only broke the connector on the sensor side and not the harness side.
wrxnofx 05-08-2022 05:56 PM
Part number is 930 606 915 00
Solamar 05-08-2022 06:53 PM
Also looks like the hose part of your vac/venturi line is cracked, probably causing a vac leak (brass tube transition to rubber hose).
john walker's workshop 05-08-2022 07:19 PM
A short length of shrink tubing will fix the hose crack for cheap.
RobFrost 05-08-2022 10:45 PM
Let us know if it idles better once the hose is sealed.
Sent from my SM-G988B using Tapatalk
yelcab1 05-09-2022 06:01 AM
Originally Posted by wrxnofx (Post 11686895)
...If you’re lucky you only broke the connector on the sensor side and not the harness side.
You got that backwards. He is lucky IF he broke the engine harness side. That connector is a dime a dozen (in black) and he can swap the pins over without even crimping on new ones.
If he broke the connector on the sensor side, he would have to REPLACE the entire sensor and that can become something really big, especially if the sensor refuses to come out of the head.
Quicksilver 05-09-2022 03:10 PM
Good catch!
Another good fix is to cut off the crimped collar, remove the rubber and then use two different sizes of hose: one to fit the small tube and a larger one to fit the larger. The larger hose will fit over the smaller and a simple hose clamp makes a conventional seal.
911obgyn 05-10-2022 08:01 AM
If you put a bit of hot glue on the cracked hose and shrink over it, you have a solid connection. In the electrical terminal you can temporarily plug it back in and zip tie until parts come in.
Tippy 05-10-2022 08:40 AM
Broke mine the other day, too!!
:mad::mad::mad:
Quicksilver 05-10-2022 11:53 AM
BTW - The connectors are called "Junior Power Timer Connectors". Make sure you get ones with the correct number of connections because that style of connector is available with different number of contacts.
