Rtrorkt's Avatar
Rear Shocks
Apparently my rears are getting long in the tooth. What is the brain trust suggestion? 69 912 tub, stock 86 3.2 fairly stiff torsion bars. Fronts are 3 years or so old.
'86 944T black/red, chip, fuchs 8's and 9's- Sold
'97 Boxster silver/red, big mistake - Sold
'99 C2, silver/black, RoW M030 - sold
"69 912 white w/ '86 3.2L (like the pic, just not the pic)
Old 05-06-2024, 04:17 PM
Schulisco's Avatar
Basic rule: The stiffer the torsion bars, the softer the shocks...
Either Bilstein series replacement (which was the sport option from factory) or Koni red (adjustable). Never Bilstein sporty road setting! Those are the stiffest shocks by far. And for a lightweight '69 way too stiff and therefore uncomfortable. But well - they have to fit as well to the fronts. There are Bilstein catalogs with the settings as PDF and online catalogue available.
http://www.bilstein.de/fileadmin/user_upload/pdfs/classic_cars/Klassik-Katalog_08_%202010_final.pdf
https://bilstein.com/en-us/products/
Just my 2cents.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 05-06-2024, 04:39 PM
Koni Red By a landslide
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 05-06-2024, 08:29 PM
PCA Member since 1988
Koni classic (red) or Koni Sport (Yellow). If Sport, start with the softest setting. I run Sports in my 1973 with 3.2 engine.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-06-2024, 11:43 PM
Rtrorkt's Avatar
Lucky me Pelican is running a KONI sale
Old 05-07-2024, 07:58 AM
Rtrorkt's Avatar
alright guys, Koni reds are not available for my car. Koni yellow sport adjustable or Bilstein Green B6
Thoughts?
Old 05-07-2024, 05:14 PM
Rtrorkt's Avatar
I did find a part number in the Koni catalog o f82-1962 but it seems that Pelican and Sierra Madre only carry the yellow sports.
Old 05-07-2024, 05:33 PM
I find Bilsteins too harsh on light cars. Koni Sports.
Old 05-07-2024, 06:40 PM
Vons, level 1, digressive valving!
https://www.penskeshocks.com/blog/linear-progressive-regressive-digressive-shock-valving-differences-and-use-cases
Old 05-07-2024, 07:03 PM
Sure, but that's a big step up in budget.
Old 05-07-2024, 11:39 PM
Thoughts?
Here's the Koni Red that fits 1973 cars. It should also fit your 1969. Call Pelican and ask for Glen Sager. He will know if they fit.
https://www.pelicanparts.com/More_Info/KON821756.htm?pn=KON-82-1756&SVSVSI=4247&DID=1
Old 05-07-2024, 11:58 PM
Rtrorkt's Avatar
Pete, will do that this morning. The complication is when the clone was built it was done in shop doing 911 spec racers which underneath is what it is, all 80’s suspension bits. Begs the question is the fitment to the suspension or to the basic tub?
Old 05-08-2024, 05:20 AM
Rtrorkt's Avatar
not that it is important, but the suggest fitment by Pete seems to be right and 2 are on their way to my shop. Thanks all for the help
Old 05-08-2024, 09:21 AM
Bill Verburg's Avatar
Just my 2cents.
Thomas
Choosing damping ratios is a black art w/ many input variables
here's the basic model for a single wheel
ms is the suspended mass, mu is the unsuspended mass, ks is the wheel rate provided by the spring, kt is the tire rat,e cs is the shock damping, ct is the tire damping
here's what undamped over damped and underdamped looks like
a stock 911 rear has a rear wheel rate of ~107lb/in w/ a ride frequency of 1.137
this a a very comfy setup that wants ~80lb/in of damping+/-
change the t-bar to say a 27mm and the wheel rate goes to ~202lb/in w/ a ride frequency of 1.563 which wants a damping rate of ~152lb/in
ie stiffer spring wants a stiffer shock
one of the better shock choices is MCS
here is a graph of their digressive damping ratios
you can certainly find the setting that you want on these shocks
the more mudane shock cjhoices can be hit or miss
Bilstein's tend to be overdamped, which feels harsh but do a digressive revalve and they can approach the MCS for at least one spring rate selection
here's a comparison of Bilstein hd and sport rears
they have linear valving that's pretty good for 23 to 27mm rear t-bars the sports form 256mm up
here's what a digressive revalved rear would look like compared to a sport, these have a much wider range of t-bar application
it would be nice to see similar curves for the Konis
Bill Verburg
Old 05-08-2024, 02:06 PM
It would be nice to see the curves for Konis. I never have come across them.
IN the case of shocks, I trust my "butt shock dyno." I don't race my car, so I want a nice tradeoff between comfort and sportiness, but not all out performance. This tradeoff necessarily is subjective, as some people will put up with more harshness in their street cars than I will.
Rtrorkt: Please be sure to post your impressions of the Konis in your car.
Old 05-08-2024, 03:52 PM
Damping rate of ~.75 is a good starting place but tires and road conditions and MS and MT all affect that
as the ratio goes up or the spring rate goes up the ride frequency aka harshness also goes up. This also affects turn in response and other performance factors.
good rule of thumb is freq. ~1.5 +/- for street sport ~2-2.5+/- for non aero track cars, 2.5-3.0+/- for moderate downforce track cars
Bill Verburg
Old 05-08-2024, 04:19 PM
Rtrorkt's Avatar
Pete, will do. Hoping to pick it up on Monday after I get back from working the IMSA race at Laguna
Old 05-08-2024, 04:54 PM
I was told Koni 82-1756 fit on a 77 rear with 3.0 cannot confirm the validity of that but I too will be going koni reds front and rear
77 Porsche 911S with 3.0 power (79)
Old 05-08-2024, 11:56 PM
If you are a "set it and forget it" kinda guy, the Classic/Reds will do fine. You will probably end up at the "second click" in the adjustment range. They are harder to adjust than the Sports. The Sports conveniently have knobs on the top so adjusting them is literally a one-minute per shock process. Sometimes I like to fiddle with mine, so I went with the Sport/Yellow set, even though they are a little more expensive. On the softest setting, they give very good compliance on the street in my lighter 1973 car. I don't like harsh suspensions on the street.
Old 05-09-2024, 12:54 PM
