				Rear PORSCHE reflector is warped
			Rear reflector was replaced a few years ago. It is now warped in several areas - shop suspects it is related to heat from the muffler, perhaps because it is not an OEM piece (I.e. inferior quality)
				Has anyone experienced this issue? Jason
	'79 911SC Targa  |
			I have never seen that before. Can you post some pics of the damage and aftermarket part?
	Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche  |
			Is the heat shield below the reflector there?
			Yes. It happened to me. I noticed the reflector was starting to be affected and that the surrounding area was pretty hot. I made a heat shield out of sheet metal which fixed the problem, avoiding further damage. I did not know at the time there was supposed to be a heat shield there.
	1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!  |
			 Wildman Emeritus
			McMaster Carr sells heat sheet material that is reflective on one side and adhesive on the other. I cut a piece to fit the inside of the bumper and reach up as far behing the rear reflector as possible. Used to hi temp adhesive to augment the material's adhesive and stuck it in place. Seems to make a significant difference in heat in this area.
			I did have to pull the M & K to gain good access.
	Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold  |
			Or, you could spend the $50 bucks or so and install the one the factory used.
			It shouldn't be a problem that needs a new solution. Last edited by group911@aol.co; 05-11-2022 at 07:46 AM..  |
			I’ll post pics tmrrw.
			Don’t know if heat shield is there or not - is it easy to see? I had a near-full restoration done about 5 yrs ago - body stripped, top end engine rebuild which included replacing the muffler and heat exchangers. It is very possible that the shop did not replace the heat shield - their list of miscues seem to be growing. Jason
	'79 911SC Targa  |
			It's a filler panel that covers the open area below the reflector. Usually unpainted silver galvanize.
			Heat shield missing.  We just replaced one on a 76 Turbo.  Both shields missing.  Reflector melted crazy...  Replaced reflector, installed both shields, problem solved....
			Cheers
	Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3  |
			Great diagram and photo, thanks!
	Heat shield is in place Pics below may be difficult to clearly see, but sides have warped. ![]() ![]() Jason  |
			Do you have a picture of the heat shield in place?
		![]() ![]() Same as bmcfarland photo Jason Last edited by LIRS6; 05-12-2022 at 05:14 PM..  |
			That's pretty weird Jason.  Sort of bad luck I guess.
	When you have the heat shield in place try fixing the rear reflector with a hot air gun and leather gloves, instead of buying a replacement.  |
			Thanks Bill
			I was considering using heat, but think will just live with it for now Jason
	'79 911SC Targa  |
			Just start shopping for a good used one.  It can be hard to find one with all the clips on the back intact.  I think the new reflectors available from Porsche look like the newer Carrera and not like the earlier cars.
			Mark
	1979 911SC Targa  |
	Paul 2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951 1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold Instagram: @rennsport98  |
