Injector pockets and all seals were replaced with new together with injectors. |
Weird,
Almost like an electrical connection that is needed for spark is weakened when the tts is grounded and pulling current. The resistance to the power or grounds needed for the cdi being insufficient and changing with temperature/humidity/vibration, once the alternator is running the problem dissapears over all temperature, for now. Phil |
George, At this point you can not use a gas analyzer if you could not make it START. If you are able to make it start and get the motor to operating temperature, then use the GAS ANALYZER. There is something basically wrong with your CIS if you could not make it to start. If you have fuel, ignition, and the right amount of air, your motor should at least show sign of life. And disabling the CSV to make a cold motor start is a sure sign of trouble. Ask your self why would a working CSV is detrimental for a cold start? The problem is right in front of your/our noses but we are not seeing it. We could NOT solve this problem if we could not identify the culprit/s. Unless you get lucky. Do you have the correct spark plugs? If they are, then one variable to eliminate. There are so many variables involve and eliminating some of them gives us a better batting average. Unmetered air comes #1. Tony |
The funny thing is that if i let it rest for a couple of days it will start cold first crank!
How about that? Will do some tests during the weekend and if i have the time i will pressure test the intake. Phil i conected the ignition timing light and there is spark during cranking. Thanks |
I am missing something and i put you in all this trouble while it is surely something simple.
Have started with the fundamentals. Checked sensor plate alignment. Is good. http://forums.pelicanparts.com/uploa...1653597889.jpg |
I would also check both UFO/disc vacuum valves on the right side of tge engine ... If you have only one, then the second is on the left side close the throttle body.
One is the additional air valve. This valve is open until the engine creates vacuum on start. Then it shuts the channel when the engine runs. Its the one with only two connectors. The other one is the deacceleration valve. It is controlled by vacuum. It prevents popping in the exhaust when going off from the throttle. This valve also let the engine keep 2500-3000 rpms to make easier/smoother shifting before idles. If one of both is going crazy and remains open or closed from time to time this confuses the CIS and as well the machanics working on that engine... https://imgur.com/Zn1bkXn.png For a proper test take them out and test them with a vacuum pump manually... Pretty expensive if they need to replaced. Edit: I watched your vodeo again - I cannot see any of both valves at your engine...is that right? Or do your engine has the "vacuum limiter" next the throttle body (911 110 220 00) ?? Thomas |
Hi Thomas
The setup you present is for US spec cars. See below Euro configuration. All are in position on my engine. AAV should be closed once 5" vacuum is applied. I will test that also, but when this valve goes bad the engine gets crazy. Surging / high idle ect... Decel valve opens, bypassing air around the throttle plate to avoid rpm sudden drop and stalling when high vacuum induced. (foot of the throttle) http://forums.pelicanparts.com/uploa...1653640256.jpg |
CIS troubleshooting.........
George, Making your motor STARTs at first attempt is where you should focus. You need the CSV for cold start. A properly set-up CIS regardless it is a Porsche, Mercedes, BMW, VOLVO, BENTLEY, Ferrari, etc. should fire and run........and stall if you have a significant air leak or lack of fuel or weak ignition signal. The motor needs all three (3) critical elements:
Test and verify that you don’t have significant air leak. They all leak, it is a question if it is significant to affect ignition. The lesser leak the better and become less troublesome. Air leak is the Achilles heel of CIS. Good luck. Tony |
i am preparing the equipment for relevant tests.
Will do everything from scratch. I have one theoretical question. Since disabling CSV makes it start, wouldn't an air leak make it start easier with the CSV connected? it would compensate the rich start condition by inducing more air. Has anyone faced cold start fail by vacuum leak? In my experience (NOT CIS engines) even when vacuum lines are missing the engine will start but idle will be erratic or stall. I am also referring to carbureted engines w/o O2 sensor to compensate the mixture. Thanks |
George, The more you have unmetered air going into the system, the less chance you could get the motor to start or idle. You need a smoke generator to locate these hard to locate air leak source/s. Some of these leak sources could be overcome by setting the fuel mixture too RICH to make the motor start but would not run well. A disabled CSV would make the condition more LEANER plus additional unmetered air makes the ignition more difficult to attain. That is why it is critical to eliminate unwanted unmetered air in a CIS motor. I will give you a very good example. Find me a good running CIS motor and I will make it not start or run at all by simply introducing an air leak. You could spend all the time you need to make it run again and it won’t run again. Unless you locate and identify this culprit. It is not how hard you work but how smart you tackle the job. This is not rocket science. There is something wrong with your CIS set up and simply not aware about it. You are an engineer and knows how to check and verify things. Wish you the best and good luck. Tony |
I guess the very first and foremost thing to decide is to find out whether the mixture is either to lean or too rich. And George already found out that it's too rich. So my conclusion is, the engine didn't get enough air with the current settings and the connected CSV. Either the setting of the CIS is bad or it get's too less air. Yesterday I wrote also that we probably face here not only one fault...this is also my experience. Most CIS cars suffers on more than one problem. And this confuses everyone.
Of course the car can also have a vacuum leak problem (which probably occurs from time to time only without any reliable pattern). But it's also imaginable that one or more problem exist. Or that the following problems cam from a previous problem like vacuum leaks. Then you can "tune" any CIS car to run better and hiding / not solving the problem...if the next problem occurs come on top, this can confuse totally... An example: My car also still had serious cold start issues. I examined every part of the CIS...almost everything was either bad (airbox, TTS, FD, injectors, vacuum lines, switches, temp sensor) or a wrong part (in my case the WUR). I replaced them (TTS, WUR, airbox) pr let overhaul them (FD), injectors, temp sensor, switches), adjusted the sensor plate etc. And still the car won't have a proper idle on cold.... The reason I found later - that red plastic flange for the CSV was one of that false series with no hole - it was closed for the air line coming from the vacuum valves and the AAV....so the engine could not start either when cold. It immediately ran on too rich mixture every time when cold. I could keep it running while playing with the throttle. But then the mixture was quickly too lean because the engine was cold...it took me everytime several minutes until then engine was warm enough before I could get it out of the garage...very frustrating and annoyed neighbours... I identifed the problem with a smoke generator filling the vacuum lines from one of the vacuum valves and closing each other - after a while the filling line of the generator popped out due to overpressure...:eek: I already recommended to use such a device at my first posting here as Tony did as well... That's what I mean when working on a going crazy CIS car...you cannot rely on any part of it unless you examined and proved it... Thomas |
Thomas
I suppose that when you had the cold start problems the engine would not keep high idle during the cold start due to air from AAR and AAV not passing through. Correct??? Thanks |
Thomas |
Good day to everyone.
1. Performed a thorough smoke test. NONE leakage found. 2. Connected a test lamp to csv plug. Working. http://forums.pelicanparts.com/uploa...1653744402.jpg http://forums.pelicanparts.com/uploa...1653744528.jpg Going back to fuel rerated tests. Reverting |
Smoke Test...........
George,
How did you isolate the system (airbox) from atmospheric condition? A picture of your set-up would be helpful. Thanks. Tony |
I put a plastic bag on top of sensor plate body and installed the boot back into position. This way i also check the intake boot integrity.
The smoke device outlet hose was installed below throttle plate where the bottom hose of decel valve is normally connected. http://forums.pelicanparts.com/uploa...1653758394.jpg http://forums.pelicanparts.com/uploa...1653758508.jpg |
Additionally i checked spark advance during cranking with strobe light. Well eatablished around 5-7 degrees BTDC.
tomorrow will remove all spark plugs for inspection and connect fuel gauge to check pressure during start and re check residual with valve closed. Thanks! |
Good day
Spark plugs photo below. Condition looks optimum to my eyes. Some oil on the circumference but ground electrode is tan brown. http://forums.pelicanparts.com/uploa...1653845752.jpg 1. Residual pressure with valve open 1.5 bar after 30 min. 2. Residual pressure with valve closed drops instantly from 5 bar to 2.5 bar and will stay to 1.8 bar after 30 min. Please check the video of cold start after 24 hours. I think something wrong with WUR? https://m.youtube.com/shorts/GIcySvwJhXo Let me know what you think. If someone can do same test and upload video it would be appreciated. Thanks |
Watching the last video, is the control pressure supposed to be so low for the first 10 seconds? (looks like zero bar at first then very slow build up)
I am not sure how much difference it might make, but when you attached the pressure gauge, was it the day before and you ran it to clear out the air and make it ready for the test 24 hours later? Phil |
Your observation is very accurate.
Gauge was not installed previous night. Was installed just before cold start attempt. Will connect tonight and check tomorrow. What i dont understand is that when i disconnect the WUR to FD line after 1 day there will be not even a single drop of fuel although residual pressure is within spec. Thanks |
