Need tow hook with 5/8-11 UNS thread ?
Hi,
I recently installed the G-Model front tow hook receiver (bumper bar replacement tube) and now am facing the "problem" that the inner thread is equipped with a US 5/8-11 thread that is not common in Germany. My bad I didn't check that before. Did you guys come up with options on hooks/loops that have the proper thread? My search on the web does only reveal expensive options though I guess in the US there must be some regular out there in any trunk (Ford, Chevy, etc) ? Thanks @Rennline: fyi btw, the riveted aluminium thread nuts are junk, the threads are badly cut and when tightening down they turn loose. I drilled them out and attached bumper with my own solution. Recommend you rather weld threads to the plate. https://up.picr.de/43662344ve.jpeg |
I used this on my IROC project years ago. Painted it red, worked fine.
https://www.mcmaster.com/3014T919/ Good Luck |
Aluminum rivnuts for a tow hook attachment? I agree, it's not the choice I'd make.
Made something up myself of scrap I had
7 cm bolt 5/8-11 an old tow strap some shims and a 3/4 inch sleeve Will do the job in case of a (hopefully) rare need https://up.picr.de/43678563be.jpeg |
nice work flojo ..i just wonder why?....I have never seen any 911 being towed by this hook., that is factory..unless you are stuck on a racetrack...;-)
Ivan |
2nd this, I use and eye bolt from McMaster.
| All times are GMT -8. The time now is 06:07 PM. |
