915 Transmission problem
Transmission question. I have a 1980 Porsche 911SC with a 915 transmission. Recently I noticed a spin up whine when I shifted from first to second gear. On further investigation I found that after it was in second gear rolling along, if I pulled back on the shift handle, I could feel and hear a grinding sound. Once in second gear and shifting into other gears there are no other sounds.
Old 05-23-2022, 06:30 AM
Remove the 4 nut plate on the bottom and see if the guide fork that's attached to it is loose. Tends to make a whizz noise when shifting.
206 637 4071
Old 05-23-2022, 06:33 AM
Jtt84911's Avatar
Hey John….regarding your comments above^ about looking/checking tightness of guide fork…
will you loose trans oil once that plate comes off??
Thanks,
JTT
Old 05-24-2022, 10:15 AM
gearhead
Thanks,
JTT
You drain it first.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-24-2022, 10:45 AM
Thanks,
JTT
Your first time into this box?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-24-2022, 11:32 AM
Maybe let a shop so it, to be safe.
206 637 4071
Old 05-24-2022, 02:53 PM
Fixer's Avatar
Thanks,
JTT
It can't hurt to change it now anyway.
Drain it the normal way and also remove the plate and let it drip out for the night.
Good luck with it.
Matt
Old 05-25-2022, 03:49 AM
