Removing Paint On Tail Light Lenses
I want to remove the fading black paint that borders my tail light lenses (84 3.2L) and repaint, but haven’t come up with a good way to strip off the paint without harming the plastic. Acetone helps, but it’s very slow going. Anyone have a recommendation? Thanks.
Old 05-25-2022, 08:47 AM
DerkPerk's Avatar
I used acetone to remove the loose stuff and painted over what wouldn’t come off.
Old 05-25-2022, 09:22 AM
Senior Member
Test a spot with lacquer thinner.
Old 05-25-2022, 12:04 PM
try denatured alcohol. slow go but won’t ruin the plastic finish
Old 05-25-2022, 12:35 PM
Senior Member
Jdub's Avatar
Don't risk corrosive chemicals. Instead, treat the old paint as base by carefully sanding at about 220 grit to even the edging of black into a nice surface. Hot water and Dawn dishsoap, full dry, then tape and paint over.
'78 Targa in Minerva Blue
Old 05-25-2022, 12:38 PM
