-   -   1976 911 - Fuel lines - Converting from CIS to Weber (http://forums.pelicanparts.com/porsche-911-technical-forum/1119607-1976-911-fuel-lines-converting-cis-weber.html)
Alexandphoto 05-26-2022 06:24 AM
Hi!
I'm in the process of converting my 1976 911 S from CIS to Weber 40IDAs.
I have already purchased a PMO regulator from our host with barb fittings.
Looking at my existing CIS fuel lines though, they have threaded ends and I now realise this won't be quite the plug and play exercise I had anticipated :confused:
What are my options here to connect the existing fuel lines to the PMO regulator barb fittings?
Thanks!
jbuggyus1 05-26-2022 07:07 AM
on my 912e i used this fitting to convert my lines to AN type
jbuggyus1 05-26-2022 07:09 AM
http://RACETROnDE
Tom_in_NH 05-26-2022 08:41 AM
In discussions with Len Cummings (BoxsterGT), I learned that he does conversion lines/fittings for this application, CIS to carbs. Outlet of CIS type fuel filter to AN-6, and AN-6 to return line fitting.
jbuggyus1 05-26-2022 09:06 AM
i tried to post a picture with no luck https://www.racetronix.biz/p/adapter-6-jic-an-male-m14x15-female-inverted-flare-black/adf-6jm1415fif it’s racetronix 6an ivan male to m14x1.5 female inverted flare adapter.
75 911s 05-26-2022 09:11 AM
Len makes a nice two piece kit. Basically you get two lines: one feed and one return. The return is a threaded fittiting to the stock return line and hiqh quality fuel line with a clamp for the barb PMO output. The feed is similar and goes from the where the old hookup to the filter / accumulator was to the PMO. You can see pics of lens lines in my build thread toward the 21 page mark If i remember. My setup is a bit different as my fuel pump is in the back on a 75. And i had a custom AN line made with a one way check valve to help with hot starts.
Alexandphoto 05-28-2022 08:13 AM
Thanks for the suggestions guys. Being in Australia, it's a bit tricky sourcing some of these parts without a longer wait.
Fortunately though, I found a local hose shop who was able to create new hoses for me which are crimped with connectors on one end and the other end is open ready to slip onto the PMO barb fitting.
One hurdle down, a few more to go!
