FloydPink's Avatar
3.2 Carrera Brake Discs
Rotor width is getting a little thin, thinking I’ll replace all 4 corners soon. Is there a preferred brand for rotors on these cars? Porsche original parts are ~2x the cost of some of the other brands offered by our host. Also wondering about pads, thanks!
Old 07-19-2021, 05:38 PM
I did mine in March. I reached out to PMB and bought whatever they suggested, Sebro in this case.
Our host sells them too.
For pads I went with Porterfield RS-4 and am very pleased with the overall setup. If you haven’t already I’d suggest changing your lines to stainless while you’re at it.
Old 07-19-2021, 05:58 PM
oldtractorboy's Avatar
I just did mine with ATE rotors & Porsche pads.
Steel Vs Rubber Brake Lines
https://youtu.be/6LJiPDAr9f8
I'm just a dumb guy with a smart phone
Old 07-20-2021, 07:27 AM
Cairo94507's Avatar
I "second" calling PMB and following their advice. They supplied all of the brake parts (and more) for my '71 914-6 restoration and I couldn't be happier with the parts or the service. Eric Shea is a great guy who is a true Porsche lover/supporter.
'71 914-6 #0372
'17 Macan GTS
Old 07-20-2021, 07:32 AM
I purchased everything from PMB. The results were perfect.
Old 07-21-2021, 02:58 PM
I’ve been using Zimmerman on my street/de car for years and they hold up great and with the coating never rust
Old 07-23-2021, 02:47 AM
I'm good with tools.
AG81's Avatar
Originally Posted by conekiller View Post
i’ve been using zimmerman on my street/de car for years and they hold up great and with the coating never rust
x2
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 07-23-2021, 07:25 AM
cycling has-been
bkreigsr's Avatar
Buy the best that you can afford - these are considered 'wear' items.
Old 07-23-2021, 11:52 AM
faverymi's Avatar
Nothing wrong with Zimmerman.
Old 07-23-2021, 12:14 PM
You may be lucky and still have enough meat on the rotors to have them turned. I had mine done at a quality shop and my car still stops on the dime. I bought my pads from Pelican and I changed them.
Old 07-23-2021, 01:46 PM
The 9 Store
Turning cost almost as much as new ones.
All used parts sold as is.
Old 07-23-2021, 02:17 PM
I had a out of round back rotor. Had shudder when braking. My long time tire shop used a on wheel tool to turn the back rotors. . Shudder gone, car stops perfect, rotors still in spec. I installed new pads with in tolerance rotors. I know my brakes are good.
Old 07-23-2021, 05:35 PM
FloydPink's Avatar
Thanks all, just took the calipers off today to send into PMB. Will be replacing rubber brake lines as well as pads and rotors. Another question: should I clean my bleeder valves or buy new ones? If clean, is there a special chemical/solvent I should use?
Old 08-01-2021, 09:12 AM
FloydPink's Avatar
Bump, I think this might have gotten lost when the forum stopped updating around 7/31.
Old 08-10-2021, 02:25 PM
Pedro '84 Coupe's Avatar
If the bleeder screws aren't rounded off then you should be OK to clean and reuse. Maybe try some brake cleaner. When I got my PMB calipers they came with new bleeder screws though.
2000 Boxster S and 2016 Audi A6
Old 08-10-2021, 02:40 PM
After I ordered new bleeder screws from our host and somehow they didn't fit I cleaned the one that was clogged with a wire and brake cleaner. Good as new. I replaced the rubber caps as well.
Sold: 1989 3.2 coupe, 112k miles
Old 08-10-2021, 05:54 PM
It's likely obvious, but a trick on those little rubber caps is to buy a bag of assorted silicon plugs and caps from Amazon, a paint store, wherever and leave them in your toolbox. You'll find plenty of uses when working on cars to plug or cap a line, or cover threads while painting something.
I cut some shorter and use them to cap the bleeder screws to help keep them clean.
Old 08-11-2021, 06:23 AM
FloydPink's Avatar
Bringing this back to the top for a new question. Today new rotors arrived for all 4 corners (Sebro). The 2 front rotors have different finishes (one slightly crosshatched, the other relatively smooth). I'm wondering if it's okay to install these as-is or if I should order another rotor to ensure that I have matching finishes on both front left and right. For what it's worth, the rear rotors have the same smooth finish as the rotor on the right of the photo.
Old 09-09-2021, 07:19 PM
Don’t worry about it. The cross hatching is quite fine and will disappear after your first drive.
Old 09-10-2021, 12:33 AM
FloydPink's Avatar
Back with a brake update now that I've had the PMB calipers on the car for about 9 months. Wanted to see if anything I've experienced recently is unusual...
Bled the breaks yesterday and noticed this bright orange gunk coming out of one of the calipers. Any idea what this is?
Additionally, it looks like the fasteners on a couple of the calipers have started rusting. Is this normal?
Old 06-14-2022, 11:47 AM
