Speedometer main shaft vibration
Hello,
I am wondering if someone has found a solution for the problem I am facing. I have a 71 speedometer, with the cable to my 901 gearbox. The cable connect in the speedometer to a shaft which has a sort of magnet flying-wheel on the other side. The problem is that the shaft sometimes vibrate. There is a very little play, like if the shaft is too loose in his housing. There is a screw to press the flying-wheel against the main body but it doesn't help. Did anyone encounter the problem ? Any idea how to solve it ? Any kind of bushing solution ? |
| All times are GMT -8. The time now is 09:37 AM. |
