911 SC clutch pedal pictures
Hi everyone,
I have a 911 SC with a clutch pedal issue.
I am rebuilding the cluster and when I took it apart the round bushing that is welded to the pedal was not connected.
I did not notice this when disassembling and now when I am assembling the angle needs to be set.
Does anyone have a pedal they can take pictures of so I can weld it back up.
Basically I need to see the angle where the barrel pin goes thru the bushing hole.
I have a pic attached but i am worried about getting the angle perfect. Any advice appreciated.
Last edited by jeffcieslik; 10-26-2023 at 07:13 AM.. Reason: Attached pic i correctly.
Old 10-26-2023, 07:11 AM
The hole in the barrel for the pin lines up with the spring holder on the pedal. Stick a piece of tungsten through the hole and line it up.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 10-26-2023, 08:06 AM
My lines not right on but you get the idea.
Old 10-26-2023, 08:11 AM
I appreciate the insight.
I have been studying pics on the internet and at first I thought it was lined up, but the closer I looked the more I thought it was slightly to the right of the spring pin.
Was hoping someone had one laying around that could snap a pic so I could clearly see the orientation.
I can go with the straight alignment as there is some adjustability to the clutch but I was shooting for almost perfect.
Old 10-26-2023, 09:02 AM
I checked one in the garage for you just to be sure before I posted. Pictures aren’t going to help you with different ratios, lenses, screens et. If you can tig it.
Old 10-26-2023, 11:55 AM
Perfect. I will alight it dead center with the pin and weld it up.
Thank you.
Old 10-26-2023, 12:03 PM
Schulisco's Avatar
Addendum:
https://rb.gy/ad04p
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 10-27-2023, 01:17 AM
Originally Posted by Schulisco View Post
Addendum:
https://rb.gy/ad04p
Thomas
Nice photo essay, Thanks for posting.
Old 10-27-2023, 08:11 AM
