 ReFuze from CDD Autogear Thought I would give a shout out to the ReFuze product from CDD Autogear.  Don't normally do endorsements but Alan provide top notch customer service when a small part was missing from my order and the product is worth the spend.  Product is well built, easy to install and arrived in a timely manor. I have a 71 911. I didn't follow the online directions as the process seemed pretty straight forward. I do recommend taking a couple before photos to reference and use the zip ties to bundle wire groupings to make it easier. Took me about 2 hours for all three blocks. I found several wires during the process that needed to be cleaned up, and soldered a few off the groupings to make sure they connections were solid. https://www.cddautogear.com/refuze-products/refuze-1970-1973 |
 Agreed.  Great product, well built, looks great, works great.  Had zero issue other than the mounting screw for the blocks were not correct thread for '69.   I let Alan know, and he asked me to figure out the correct screw length and thread and said he was going to make sure to change it going forward. |
 Great products from ReFuze. Bought their 3-fuse block for the rear, and it was perfect. |
| All times are GMT -8. The time now is 01:07 AM. |
