Anyone know how to polish out a scratch in glass?
I had a plastic container fall from ceiling storage and scratched my 911 rear window ( with defrost if that makes a difference) . Only see the transfer scratch at a certain angle, but i want to correct it.
Anyone have good DIY process or recommend someone that specializes in this? I spoke to a detailer friend he doesn't do it. Thanks everyone |
its a pretty time consuming process - but you can use 3M Glass Polishing Compound or Cerium Oxide powder (same stuff im pretty certain)
lots of water and the compound + orbital polisher + felt orbital pad it takes a LONG time to see progress, and if the scratch is really deep, it might not be too fixable If its on the defroster side, you might want to be super careful to not polish/grind off the defroster lines this video is pretty good https://www.youtube.com/watch?v=y9la9hFWZmo |
If it was a plastic container that hit the glass; with some luck it's not actually scratched, but rather a mark on the glass. Have you tested it with your fingernail. To be sure you could go over the mark with some solvent such as paint thinners which would remove the plastic.
It's a 914 ...
What Bill said. I'd be surprised if plastic can scratch glass. Maybe some of the plastic transferred to the glass, which should come off more easily. Good point above about being careful near the defroster lines.
It may be worth a shot to attempt scratch removal in glass using good old toothpaste! A quick google search shows lots of entries using this approach. One site recommended to NOT use Colgate Sensitive Max Strength or Sensodyne because it may be too abrasive.
Daryl G. 1981 911 SC - sold 06/29/12 |
Try OOOO steel wool first.
Senior Member
I'm good with tools.
I use this with very good results......
![]() Yes on glass !!!!
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
I cannot " catch" the scratch with a finger nail, I had a friend use polishing compound and buffer but I can still see the scratch. perhaps a more aggressive compound will make a difference. I just don't want to screw up the window. I tend to wax, detail my cars by hand, don't feel comfortable using buffer.
I've done this in the past with Cerium Oxide. It took a lot of work with a buffer, couldn't imagine doing this by hand. Home Depot or similar might rent these.
Walt 82SC 3.0 81SC 3.6 |
HF? Use to use it in chem class to remove etching from glassware. I doubt if you can get any as it is highly corrosive.
Lost 2.7l engine #6141641, drop me a line if you find it. ![]()
