khamul02's Avatar
Norma torro screw hose clamp (52 or 53mm)
Does anyone know what the part number is for a 52 or 53mm Norma Torro screw hose clamp or where I can get them?
Pictured here is a 57.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 06-07-2022, 10:50 AM
Administrator
Matt at Pelican Parts's Avatar
We might be able to source it OEM for you. What part of the car does this go to?
-Matt
Old 06-07-2022, 01:46 PM
khamul02's Avatar
Matt,
I have a large port aluminum airbox that I plan to use on my small port 80 SC. I have sourced some adapter hoses to make this work but would like to get some stock clamps. It isn't really a stock size. I have a 54mm clamp but I have to tighten it all the way down which looks out of place. I think a 52 might work but a 53 will definitely work. I would like to try both if possible.
Tom Hutchinson
Old 06-07-2022, 03:19 PM
khamul02's Avatar
I just found a 52 online. It's a 1963 Mercedes 300SL Roadster radiator hose clamp. I ordered one to see if it works. I still need a 53 in case the 52 doesn't work.
Tom Hutchinson
Old 06-07-2022, 03:43 PM
