Targa_PB_78_SC
three vs two fitting fuel accumulator saga
Well since '84 my, '78 SC has been fitted with the two fitting accum.
Added a new one in '06 (two fitting) which cured a hot start issue then. The PET shows the two fitting accum! I get that it's supposed to have the three fitting but I do not have the correct hoses to and fittings to get there. "Boxter GT" [hope the ID is correct] builds these hoses but only if I provide the fittings. Questions: 1.) Is there as easy test for the two fitting accumulator (I've seen Tony's drip test for the three fitting)? 2.) Does someone have the fittings for the bottom of the (3 fitting) fuel accum so I can get a hose built? My problem is not a hot start one, it's a cold start after sitting for a week. Takes lot's of cranking to get fuel to the injectors. Might be one of three things? A.) Slow leak in accumulator? (no fuel at the bottom) B.) Check valve in the Fuel Pump (it's original as best I know) C.) O-ring bad in the fuel pressure regulator 3.) If I get a three fitting Accum and block the bottom, is it any safer than the two fitting one? But might be easier to test for the next owner. Issue is not a show stopper, but is annoying and I'm out of "mole-hills" right now. Here is a picture of my t-fitting cluster flop.
BareRearedRookie |
The 3 fitting is a fire prevention if the diaphragm fails in the 3 fitting the fuel is returned to the fuel tank. With the 2 fitting the fuel will drip out the bottom and potentially cause fire.
930.110.514.00 Bruce Last edited by Flat6pac; 08-01-2020 at 06:39 AM.. |
El Duderino
Mike,
I don’t know if this helps or not but I was just recently looking into this as I convert to EFI. I found Fuelab makes filters with an integrated check valve. See this link: https://fuelab.com/product/84800-series-in-line-fuel-filter-with-check-valve/ I was wondering if this would be a cheaper alternative to the factory fuel filter & accumulator. Not as big of an issue for me as I am going to AN fittings. I wonder if Len can make a connector that from the polyamide supply line to an AN -6 or -8 on the inlet of the fuel filter and then -6 or -8 from the outlet to the FD? First need to determine if this would replace the FA functionality. Given their cost, this may be a cheaper alternative. Just thinking out loud.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Targa_PB_78_SC
parts available?
maybe you will have a return line off your three fitting FA for sale sometime then? Once you go to EFI/ITBs. "I'm planning to spend the maximum amount possible before I convert to EFI/ITBs ... New airbox, CDI+, three fitting accum, fuel pump for CIS ... [well maybe not]" .
BareRearedRookie |
![]() Hi Mike, I am very willing to help with a solution. Can you show us a photo of your Return Line assy please? This is what I made up recently for a 78 911SC, and it has the 3rd Line connection (Left) for the bottom of the Accumulator. We cannot buy these combination fittings (Main Feed and Return) and must Re-Make the customer's original. ![]() Apparently your Return does not have this 3rd Line fitting. This is on the return low pressure side of the system. I could make up a jumper with a Tee to run a Line/Hose to the Accumulator bottom. Should not cost much. A few fittings and a length of Polyamide tube or E-85 Rated Hose. Send me a email with the photo of what you have and I will see what can be done. Len.Cummings at verizon.net
![]() Mike, I looked at your photo again, and it looks like your Return HAS the 3rd fitting, so I can easily add the Poly Line to the Accumulator. Just send this to me, its about $25 for Tube & fitting and $25 for my time. Len
Targa_PB_78_SC
You have an amazing eye, to spot the 3rd fitting off my photo. When I determine the issue culprit, I'll send you the fitting. Right now it's too darn hot to work on. And without the fitting I'm not sure I can run pressure tests. I took the screw off the bottom of my accumulator and no fuel came out, so the diaphragm might be okay.
BareRearedRookie |
Mike, You have the connection for the fuel accumulator bottom port as shown in the above picture you posted. All you need is a fuel injection rated hose to connect the fuel accumulator drain port to the main return line. Removed the plugged fuel line in your picture and connect the new return line with the correct fitting for the FA. Tony |
Targa_PB_78_SC
trying to understand the effort involved before I start this path. From Len's picture: 1.) Blue oval goes to accum 2.) Green circle from the front of the FD? 3.) Red circle goes where? 4.) The part in the green oval screws onto the fuel return line? And Len, if I decide on this upgrade, I send you the whole thing in the picture from my car and you add the line to tha accum? If there is an engine drop involved to get to the lines, I will likely stay with the poor two fitting piece accumulator for a while ![]()
BareRearedRookie Last edited by mike sampsel; 08-04-2020 at 02:09 PM.. |
Wrong return fuel line.......
Mike, This is not the correct return fuel line for ‘78~’79 SC but it will work. Right now, your WUR return line goes to the back of the FD. Go check it and I am also an owner of a couple of ‘78 SC’s. The fitting inside green circle is for the FD return line that goes to the backside. Looking very closely at the picture, it looks like an extra nipple was added or welded on for the extra line in green oval. If you know how to install a Cohline plastic fuel line plus the correct fitting are all you need. Or send it to Len for proper installation. Tony |
Additional pictures of return fuel lines.....
Mike,
Found some old return fuel lines for early SC’s in my junk box and a picture of the SC motor. ![]() ![]() ![]() Tony |
Targa_PB_78_SC
Thanks so much for the great pictures Tony. Nice of you to share your knowledge on the subject. Much appreciated. I'll look more closely at the lines.
BareRearedRookie |
Targa_PB_78_SC
So it looks like “all” I need to do is disconnect line number 62 from the back of the FD. Then I could get the part out. Would have been easier with the engine out. Doh!
BareRearedRookie |
![]() The Red circle in photo of post #11 above goes to the cold start. Don't recall the customer this was made up for, but I was told it's a 78 SC. US or Euro I don't know. Len
Targa_PB_78_SC
Mike
BareRearedRookie |
Discrepancy.........
Len, This is an old post and you might not be able to edit your post. The cold start valve is connected to the delivery fuel line and NOT to the return line. I have attached pictures of the OEM return lines. Tony |
It is unlikely the FA is responsible for the original problem - hard cold start.
If you wish to proceed to 3 port FA be my guest. But it is unlikely to fix the issue. Other places to look Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Targa_PB_78_SC
Was thinking of the three fitting for safety and originality plus the hope a new bigger accumulator might help the hot start. Maybe I need to run pressure tests after the car gets into its hot start funk? I’ve tested the FD for consistency and all the injectors delivered the same amount of fuel. I guess it’s possible (long cold start) the CSV runs too long? Flooding the car while the System pressure builds, but starts after a few seconds don’t let the CSV run too long (assumes the TTS is letting the CSV run once engine is warm). Anyway, will be getting CSV components tested soon. Any testing ideas are appreciated. Might be best to proceed with a plan once the CSV state is determined. |
You indicated at Post #1 that Hot start was not a problem, but cold start was.
That takes you some place else from the FA. If Hot start and cold start are both issues then there are many places to look. Alan
