Need Help Determnining if '77 911S is CA car
All
I'd like opinions on whether my '77 is a CA car or other 49 states. I'd like to know because the factory timing at idle is different for CA and I heard the CA cars run hotter because of emission equipment. First, I believe the car does not have thermoreactors (please see pic) ? It does have though an air pump with a single rubber hose going to the exhaust. The car runs at around 210 F consistently now- I did install an 11 blade fan, turbo valve covers and did a valve clearance which together brought down the temp from 225 ! Also, the door label says non-catalyst car. The car was originally purchased in CO, but dealers do swap cars. The above mentioned leads me to believe its not a CA car, but the confusing part is that the label in the engine compartment says complies with EPA and CA emissions and only gives timing settings for CA. Thanks Tony ![]() ![]() ![]() |
Look up the engine code. I did that recently to determine is my engine is original. It's on the right side at the bottom of the fan housing, IIRC mine said 06/930 which is a 79' California car. I'll see if I can find the engine codes.
1979 911 SC Gran Prix White. Gone but not forgotten. 2016 GT4, current steed. IG @hulley31 |
Code located here.
![]() The engine series and serial number is in red The engine code is in green The pressure warning light wire will be broken soon, in yellow
____________________________ If it's not leaking, it's out of oel... |
Ayo Irpin, Ukraine!
LOL, that's funny!
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
