North Coast Cab's Avatar
How Fo I Anchor The Battery?
Battery is very heavy and doesn't appear to move, but needs to be anchored for the Autocross this weekend. Is there an easy modification?
JG
1985.5 944 GTS
Old 05-26-2003, 04:37 PM
banjomike's Avatar
Right in front of the battery there should be a whole for an 8mm hole. A washer and a bolt would do the job if your battery has a lip on the front. If you want to do it right buy the battery hold down clamp which can be found here at Pelican Parts. If you battery doesn't havet that front lip on the bottom, then you'll have to get creative.
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 05-26-2003, 04:59 PM
HarryD's Avatar
Here's an idea:
battery mounting / hold down strap
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-26-2003, 05:22 PM
