Clutch cable length
I have euro 74 911 coupe.
I want to change the clutch cable and shorter from taking it out, how do i know the size of it? I see 82.6" and 77.6" lengths avaiable. Thank you
1974 911 coupe 4 speed |
Administrator
Hi kavadarci
Perhaps someone could chime in but are you able to see it at all? If you can find a part number on the outside it could be identified that way. I found an older thread where they go into the discussion about determining what cable you need and list all the different part number used: https://forums.pelicanparts.com/porsche-911-technical-forum/1037053-clutch-cable-too-short-help.html -Matt |
