Sensor ID Help Please, 3.6 conversion
Need a bit of help. Trying to wire some warning lights through a Link ECU to a Canbus display.
Oil sender, oil temp behind that got that. But what is the Bosch 2 pin sensor behind the oil temp? Can't figure it out. http://forums.pelicanparts.com/uploa...1655236519.jpg These unplugged sensors that are disconnected on the fan shroud. Are these CHT sensors? http://forums.pelicanparts.com/uploa...1655236519.jpg Thanks for the help! |
| All times are GMT -8. The time now is 12:21 PM. |
