Door stay problem
Hi All, I am breaking in a -71 911T that I have restored in five years.
The door stay on the passenger side is loose at the A-pillar. On my drivers side it is firm with some flex. How much trouble am I in? Is it possible to fix this from "behind" (the other side of the A-pillar). How was it mounted originally? Image of my drivers side from the assembly. Thanks for any input. Jörgen Forssling Gothenburg SWEDEN |
KR, Jörgen |
Senior Member
Your gonna have to have someone carefully tig weld it, there’s no access and I believe all the kits made are for the door not the pillar. I doubt you wanna rip it apart after fresh paint.
If anyone have any other suggestions, let me know. KR, Jörgen |
All that to avoid a couple of small tig welds and repaint the A pillar? Take a deep breath.
Senior Member
Cutting a piece of the panel out and welding it back will leave an exposed weld bead, weld through primer isn’t the greatest stuff. It’s just the door stay, put a neat tig underneath and call it good.
I really appreciate your fresh input. When this happened I just saw no other way. I have put five years into this and wanted it to be as good as I could doing it by myself. I guess a little short cut on the door stay is OK
![]() Thanks, and heres some images of the finished product. //Jörgen |
Senior Member
Nice car like the orange on white. 5 years isn’t too bad for doing everything yourself.
Don't know whether it applies to you but on some 80s Era Mercedes, the sheetmetal on the a-pillar cracks near the hinge.
Those cars aren't as expensive as the Porsche so people drill through the sheetmetal into the hinge backing plate. The final step is to tap and hold the plate with some nice metric screws. The screws go into the backing plate and take the stress off the a-pillar. I'm going on 10 years with a car I did this to. The screws have stayed tight and I haven't had to do anything else. |
The 9 Store
Pretty car. Congrats!
All used parts sold as is. |
(man/dude)
Nice car!!!
If you have the skills and perseverance to put that thing together, I feel like you are going to be disappointed with anything other than a proper, invisible to the eye, repair.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Thanks for your input though... ![]() //Jörgen |
Thanks for all the kind word about my car!
Took it for a drive today and stopped at my TIG-guru. He wanted to do it the hard way... From the backside. He was talking about drilling four holes in the A-pillar and plug weld it. So, do anyone have any input on how the bracket was originally put in place? Thanks for all your help. //Jörgen |
