-   -   Swapping new key handle? (http://forums.pelicanparts.com/porsche-911-technical-forum/1121141-swapping-new-key-handle.html)
Miniwerks 06-18-2022 09:59 AM
Bought a new key handle and took the old key handle apart. Not sure how to remove the key though. I don't see where the handle can split apart where the key is held. I assume it pulls out with some force? I would rather confirm before giving it a try, don't want to damage the original handle.
http://forums.pelicanparts.com/uploa...1655571540.jpg
john walker's workshop 06-18-2022 10:06 AM
Twist on an angle.
Miniwerks 06-18-2022 10:08 AM
dg567 06-18-2022 11:33 AM
You need to pry the halves apart and there is a tiny spring and a small plastic key lock that holes the key blade in the plastic part.
