Brake light wiring (1984 Carrera 3.2)
Hi,
My rear brake lights are not working (both sides) on my 1984 Carrera 3.2, RHD UK car.
There is 12V at the downstream switch terminal when the brake is pressed, so that seems good. Additionally the sidelights work which seem to be on the same ground.
Looking at the wiring diagram in the porsche workshop manual, if I'm reading the diagram correctly there seems to be a black/yellow wire going from the switch to pin 4 of a 4 way connector, ID 76. This connects to a black/green wire which continues to the RH light, and then finally a black/yellow wire doubles back to the LH light.
Does anyone know where this connector 76 is located, assuming I've got it right above?
Many thanks!
Old 06-21-2022, 12:22 PM
Look in the wiring book there is a page that shows where all numbered connectors are.
Daniel
it's not leaking....it's just marking it's territory
Old 06-21-2022, 07:38 PM
Tags
brake , connector , light , wiring
