P&Cs came from pelican. Most of the other parts were sourced by my wrench
https://www.pelicanparts.com/More_Info/PS98015.htm?pn=PS98-015-M362&q=ps98 I’m not too far from Summit Point, and the heads and cam towers were redone there. I dropped the engine and brought to my wrench, which he appreciated due to space constraints at his shop. While I had the car at my place I did a couple of things like replacing the worn engine skirt and getting the rear bumper repainted (it was off anyway, right? PM me and I can share shop names if you’re ok with shipping parts for refurbs. Quote:
Most dynamometers worth their salt already correct for atmospheric conditions using the SAE J1349 standard. So, unless correction is disabled, no post test factor should be added.
Additionally, never, ever, ever, add driveline loss factors to the result of a test performed on a DynoJet dynamometer. DynoJet has been adding a pseudo driveline loss correction factor to ALL test results since DynoJet built their first dynamometers. Its a total BS result, always reporting inflated numbers, which of course made for very happy customers lol! It's a black-box factor, that DynoJet devised when testing their first motorcycle chassis dynamometer with a Yamaha V-Max. Yamaha advertised 130 HP (approx) at the time for the V-Max, but the original DynoJet reported 90 HP! So Mark Dobeck, founder of DynoJet, came up with a BS factor, that to this day is based on the original testing of the Yamaha V-Max! Crazy. I worked for a dynamometer manufacturer for 15 years, manufacturing a wide range of engine and chassis dynamometers. Those BS DynoJet reports were the bane of our existence! The bottom line is, if you want accurate flywheel HP numbers, test on an engine dynamometer..... |
My wrench asked about that too. We have 93 octane where I’m at, which I use exclusively. Don’t perceive any issue with this.
Tom
As someone involved with racing series rules and balance of performance to create classes with some parity between models, dynos are of particular interest. My personal experience with my local Dyno-Jet guy is that the sheets I, and my buddies, have gotten are the rear wheel hp/torque figures. The only corrections were "SAE corrected," which I assume were for altitude/barometer (ambient listed on the sheet), and temperature (also listed), and "Cf=1.20" - which I don't understand - coefficient of friction on the drum?)." Some amateur racing organizations rely on Dynojet figures for BOP purposes. Leaving aside the variables inherent in a drum dyno (like how tight the restraining straps are cranked up), are you saying all Dyno-Jet figures have a built-in drivetrain loss figure? I always figured that I get to add whatever drive train lose figure I want when trying to compare my engine to engine's whose HP is at the flywheel. |
| All times are GMT -8. The time now is 04:50 PM. |
