How is the wiring to the cigarette lighter accessed? My '80 911SC coupe has a metal shield that runs under the cig. lighter, the
rear defrost switch and the fog light switch. The cig. lighter socket is only hot when the ignition is on, and I want to rewire it so that it is hot all the time. No, I don't smoke, but I would like to recharge my cell phone occasionally when I am not in the car. The only access that I could even imagine is thru the trunk which would require removing a lot of hvac hardware. Another possibility would be to mount a power outlet in the trunk and use that for a charging port while out of the car. A big plus is that the phone is locked up out of sight. Any other good ideas out there? Thanks, Fred Cook |
Author of "101 Projects"
I usually can reach these items by pulling out some of the gauges in the dashboard...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Actually, I think that I might mount one in a door pocket so that I can charge the phone and keep it out of sight/way at the same time. I considered putting the socket in the glove box, but really don't want to give up the space. I don't know what amperage he phone charger pulls, but probably not much
Fred Cook |
