911SCRVA's Avatar
Loosen oil cooler?
I'm trying to loosen the oil cooler in preparation of installing the thermostat (things are cramped and lines are overlapping). Are there only three nuts to loosen--one above and two under?
Thanks.
Old 06-23-2022, 01:12 PM
Administrator
Matt at Pelican Parts's Avatar
Hi 911SCRVA!
We have an article in our DIY section that could be helpful to you:
Oil Cooler Replacement
Sections 8 and 9 go into detail on how to wrestle the unit out and mentions:
Once the two top nuts are removed, remove the bottom nuts from the cooler. If all the sheet metal screws and shroud bolts are removed, at this point the cooler should essentially fall into your hands
-Matt
Old 06-23-2022, 01:59 PM
911SCRVA's Avatar
Thanks, Matt!
Originally Posted by Matt at Pelican Parts View Post
Hi 911SCRVA!
-Matt
Old 06-23-2022, 02:06 PM
