-   -   SC rear center reflector question (http://forums.pelicanparts.com/porsche-911-technical-forum/1121511-sc-rear-center-reflector-question.html)
ramonesfreak 06-23-2022 06:20 PM
I’m wondering if the part circled below (sorry I stole someone’s photo) is removable?
Problem is I caught a towel on the reflector and it pulled on the reflector a little. The reflector didn’t pull out from being clipped into the sheet metal. Rather, the reflector seems to have pulled away from the part I circled with the circled part still firmly attached to the car….and just in one spot along the top edge
I’m wondering if i should get a drop of epoxy in there, leave it and be careful not to make it worse going forward or something else to prevent losing the reflector…..though I doubt that’s possible
http://forums.pelicanparts.com/uploa...1656036771.jpg
David Inc. 06-24-2022 05:26 AM
They're "removable" in that they're separate pieces but they're glued to the reflector. If you want to get a bit of epoxy in there and hope that it sticks it's worth a shot and it won't damage the part in the future.
ramonesfreak 06-24-2022 11:18 AM
ok thanks.. that's exactly what I needed to know
