Wildman Emeritus
Alt Air Deflector 80SC
Can somebody spell out the proper air deflector orientation on my 3.0?
Duh, had the thing marked but then cleaned it and took off the markings. Been apart a while waiting for cerakote and have spaced on this issue. Search only turns up 3.2 which is a different deflector. Thanks
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Wildman Emeritus
More clarity.
Looking at the fan/housing assembly from the front, where are the fins located - 9 o'clock, 12 o'clock?
Think of the rotation direction of the fan... the blades are there to try to make sure an equal amount of air passes over the left side and the right side of the motor. Without the deflector blades, most of the air would be thrown to the right side of the motor, 4,5,6.
Always learning. www.aircooledporsches.com.au |
Wildman Emeritus
Thanks, Mike. Bentley, 101, etc. do not have note or a clear pic of this. Since this is a PITA to assemble in the car, I only want to do it once. Hi ho it's off to the garage I go. and get 'er done.Load some music
This photo might help. it would be turned around when installed I believe.
Matty 1979 911 SC RoW Slicktop Last edited by MotorWorks; 06-26-2022 at 12:00 PM.. |
Wildman Emeritus
Thanks. Installed and running without any major cursing. Small space and big paws.
Did manage to scratch my freshly cerakoted housing though. Ugh!!!
