Hall sensor EFI madness
Hey everyone, need help from the collective as the AEM tech department is about as useful as a chocolate teapot regarding this issue.
Car and engine: 74 Carrera. Aem infinity twin plug 2.8 motor, 12 coil on plug, ITBs, the works. I am using Rasant's cam/crank signal unit which plugs into the distributor hole. A couple months ago I dropped the engine to mess with the cams a bit, upon re-installation was when this issue arose. Here's the issue: The crank or cam sensors give out i.e. lose signal, but only once the engine is hot. Everything is 100% a-ok when cold/warm, but once it's fully warmed up everything hall signal related becomes intermittent. I can get the engine restarted, but it's intermittent once the engine is hot. here's what I've done so far: -replaced both hall sensors. Honeywell LCZ used on crank, and ZF cam (both have heat ranges up to 150C). Same type sensors the Rasant unit came with. -replaced the shielded wires for both cam and crank sensors, and grounded the shielding -checked and set air gaps -checked the pins and harness into the AEM Infinity brain itself to make certain they are tight -checked power source for sensors and ECU overall AEM has no idea what it could be. I sent the ECU and a datalog back to them, it all checked out fine sans the datalog obviously showing the crank/cam sensors coming in and out at fully warm. AEM said it has to be a wiring issue. Well, I've replaced the shielded wire twice now, soldered all connections, tried different brands of shielded wire just to make certain. It's not that. Rasant doesn't know what's going on either anyone with ideas?
No physical quantity completely explains its own existence |
It's a 914 ...
Do you have access to an oscilloscope to check the wave pattern of the signal?
Check grounds? Does the body of the sensor ground via the motor?
Sent from my Nokia 7.1 using Tapatalk |
Oscilloscope shows normal signal, until it goes out, at which time the scope depicts it as a huge spike.
Heat is the trigger for this issue. I am wondering if I just received a faulty new hall sensor that does not perform as advertised at heat.
But why would you have four bad sensors all at the same time? Possible but unlikely, right?
Put an ice pack on it after it goes to spike and see if it comes back to square wave?
Rutager West 1977 911S Targa Chocolate Brown |
Agree, hugely unlikely. When I popped the engine back in, I actually did find the cam sensor was bad as I was getting no signal when logging while cranking. I replaced both while I was at it 'as long as I'm in there' type thing. Engine fired right up once sensors were replaced.
If they're on the distributor the sensors shouldn't be getting all that hot anyway. Aren't they in the relatively ambient air outside the shroud?
Yeah I don't think they could get to more than 200F, and even that's probably high. My air temp sensor in the air filter shows max temps of 140F, but it's not bolted to the engine. The distributor is, after all, attached to the engine. Not supposed to be an issue though with that rating.
could it be noise messing with ECU. I had issues with VR signal drops and eventually found it was caused by noise from distributor rotor phasing being off at some load settings. Noise could cause this I believe. Ignoring the temperature observation but since you changed most other things already...
80SC (ex California) |
El Duderino
Here’s a left field idea riffing off of trond’s comment. Is there anything in your setup that changes once the engine warms up? Like a sensor that grounds when warm? Just wondering if it’s not heat but some other signal that coincides with the engine being warm. Maybe that signal is interfering when it appears?
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Very aggravating. Not familiar with your system, but is one sensor reading directly off the crank and the other directly off the cam, or does it all happen in some gadget that replaced the distributer? And you have seen the signal drop out with your scope? Have heard of starters needing to be shielded even when not in use.
I'm investigating something now, it looks like the bottom of the fan housing might be touching the trigger wheel a tiny bit as I do see a trace amount of metal powder/flaking on the crank sensor. Belt adjustment may be needed. Wondering if perhaps there is some movement occurring once the engine is hot that is causing trace metal to flake and affect the sensor?
The Rasant sensor pack basically looks like a distributor without the cap. It hangs the Hall sensor off the side, which reads the crank. Inside is the cam sensor wheel, cam sensor just sticks in from the top and reads.
Racer
So I tried to use a hall sensor for my 60-2 flywheel on my 3.6L race engine. Rasant built the harness for my MoTec M130 ECU and shielded the wires for the cam and crankcase sensors. The hall sensor worked fine right up until I picked the car up from being tuned. Then it started generating "missing tooth" errors. I thought I had a failed sensor so I bought a new one but the problem persisted. The harness checkout so we were at a loss. I checked ground and added more grounds. I tried several different air gaps. The MoTec oscilloscope screen showed a clean signal with nice square waves.
Then someone told me that I should be using a reluctor sensor in that application. So, we replaced the hall sensor with a reluctor sensor and all has been running great ever since.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion Last edited by winders; 08-21-2020 at 02:04 PM.. |
No physical quantity completely explains its own existence Last edited by lvporschepilot; 08-21-2020 at 05:40 PM.. |
Racer
I am using a MoTec M 4-APX-001.
I am using a flywheel with a 60-2 tooth pattern for the crank sensor setup.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
I would rather be driving
What toothed wheel are you using? A 60-2 pattern at the diameter of a 911 pulley puts the tooth/valley width narrower than the sensor. In this case, the release latch hysteresis can sometimes cause a missing tooth or extra tooth depending on the crank angle with the internal electronics. In this case a 36-1 pattern will have a wider tooth "angle" and better detection at higher rpms.
A magnetic or "reluctor" sensor will usually have a smaller detection window and not have the same tooth angle count limitations.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
