Lots of great info here as I have been considering the best route to go for an A/C system in my 911. One question for those of you that don't seem to have any issues in high temperature areas - are you running R12 or R134a in your system?
Best money I spent on my car. Great customer service and quality parts. Been running Griff's since 2008 and put 85K miles on the car with his system so it gets used a lot. Good luck! |
FWIW, Griff is currently out of the fender condensers. None expected until fall sometime. Said my starting place should be with a reliability package. I'll dig in to see what's included in that. I also need to make sure that anything not included is working well enough that the package will do some good. I'd hate to spend the money and find out that it doesn't fix the problem.
I live in Miami and have experience with several different AC systems. My present system has a single rear counterflow condenser with two electric fans and the car stays cold. It’s a 1977 911.
Why would you want all those condensers and hoses? |
Here is my personal experience. I have an 82 Targa with whale tail and an 81 coupe with duck tail. Both have the Griffiths reliability system installed. The Coupe has marginal cooling and the Targa very effective. The Targa's grill has 50% greater surface area than the coupe plus the louvers are angled in such a way to collect far more air. I am rethinking adding fans to the coupe as a winter project. |
"I'd hate to spend the money and find out that it doesn't fix the problem" Best if you define the problem, the possible solutions and your expectations. |
When I went to the four condenser system way back in 2007, beside the cold air, they secondary improvement was cooler engine temps. With the fans on the front and two fender condensers blowing the heat away from the engine, it simply ran cooler. Especially when I am going slow in traffic.
The trip down to Key West is the longest trip I ever made at 35 MPH. And more than a few stop lights, and even slower sections. July in the keys is not a cool place temperature wise. |
I installed a single condenser Electric system from Classic Retrofit. Living in a hot and humid area of the SE, I can say that it is barely tolerable on hot days and can't keep up on very hot days.
"I talked to a guy at Patrick Motor Sports and he said they don't use 4 condensers (and that was confirmed by Griffith)."
True, we do not market our fender condenser systems through Patrick Motor Sports. Today I checked the pressures and the high side was only 200 at 95F. I added 4 oz of freon and now the pressure (tested per the Griffith procedure) is 250. Vent temp before adding freon was 55F and after was 41F. Much better! The shop that did the initial charge only added the recommended starting charge of 31oz and said it was good. Pays to read the directions. |
Where are the Griffith installation instructions? I'd like to review before deciding.
If you can assemble IKEA or a kids Christmas toys, you can do all the installation with a standard set of tools. It is all pretty easy, if not kinda dirty replacing the hoses. The only part that is scary, or technical is charging the system. That is pretty wasy, but it takes some special equipment and tools. Many people take it to a pro for that step. |
Well, now its going to be no fun assembling systems. Griffiths (and mostly everyone else) cannot supply compressors. Griffiths is quoting September/October for fender condenser kits . They still have front and rear condensers in stock.
We just ordered those along with the barrier hose kits for a couple jobs in the shop. We just ordered the last compressor upgrade kit from one of their distributors (Hope it is actually coming from their shown inventory) |
One of my friends is having AC problems at their house. They have called several local companies for help in a replacement system. They are hearing 20 to 30 weeks out for any new units. Everyone is out of stock, and has none coming in for a while. It is insane.
lots of central units and tons of mini splits too now geting a repairman in a heatwave is always tuff I just put a windowshaker in the BR until we fix the central unit and the guy is coming today |
| All times are GMT -8. The time now is 09:25 AM. |
