901/3.2 Drivetrain moving in Reverse
Hi Everyone,
Just picked up a Avanti/Beck 904 with a 901 transaxle and 3.2 Carrera engine. It's a blast. Except I can't move in reverse without violently shaking the rear of the car. Took a video as I was barely moving in reverse and you can see the 901 transaxle vibrating quite a bit. https://www.youtube.com/watch?v=RVEzhbB0zzg&ab_channel=TF39 Does not vibrate when rear wheels are off the ground. Motor and trans mounts appear to be in very good shape. Suspension needs to be reworked for the street as camber is aggressive in the rear, and the front wheels touch the inner fender. Wheelbase is same on each side, so I would not expect this serious of vibration at such a slow speed. |
| All times are GMT -8. The time now is 12:12 AM. |
