Plug for 1970 911 body panel
Anyone know what to use to plug the seatbelt bolt access hole in an F series 911? Mine is 1970.
The one under the rocker panel.
Never seen that before, bolt for seat belt is on the inside.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Shouldn’t be a hole there, sorry
I agree, that shouldn't be there.
1970 911T "Albert" 1986 944 Sold 1980 Euro 924 Sold 1967 911 Sold but Greatly Missed!! |
Unless I'm mistaken that's where the jacking point goes.
Shown here with half a pound of New Mexico sand. ![]() Sent from my SM-G988B using Tapatalk |
Full Send Society
Is that a bolt I see in the hole? Find the function of that bolt and you’ll have your answer for why there’s a hole and whether or not you can fill it…. Then again, a trip to the hardware store and a $1 will see a plastic plug make quick work of that hole.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
There is a hole on both sides of the car in the exact same place. It's an access hole for the lower seat belt pivot. I used it to install new seat belts. It is there from the factory as there is no other way to get at the bolt. And the original seat belt was anchored in the same spot.
Nope, seat belt is anchored to the seat rail bracket.
It’s a small bracket that mounts between the seat itself and the sliders
Not the safest construction out there and most likely why you see the modification on your car
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
That explains it. I'll find a plug after I get done rust proofing it. It had plugs before so rust is only surface type.
Under the radar
Some of the early cars had a nut welded into the inside rocker for mounding the seat belt if the car came with the optional retractable belts. You may want to check under the carpet on the rocker panel toward the rear of the door opening. Mine did not have that nut, so I added one.
