G body fiberglass front bumper turn signal advice
Looking for how some handled putting in turn signals into the TRE or euro racing design front bumper. It looks like they tried to mimic how the signal bucket was laid out slightly. I can easily attach the lens directly to the bumper, but then what do I do about the light source. Did some use an LED strip?
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Full Send Society
If you do use LEDs you’re going to have to change the relay… not terribly complicated but the original won’t work with LEDs.
Alternatively, you could drill a hole for a standard turn signal bulb socket and epoxy it into the fiberglass. You can probably get those on Amazon for cheap. Or harvest them from your original turn signal bodies.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
