Cam Chain Tensioner Part question
While doing some updating to the car i opened up the cam chain tensioner covers and found these tensioners in the car. They aren't OEM obviously.
Does anyone know what these are or can tell me something about them? The collar around the shaft is different and has a set screw in it. The shaft itself appears to have a larger diameter than the regular tensioner as well. http://forums.pelicanparts.com/uploa...1657576175.jpg Thanks, Rob 1970 911S |
They were a self adjusting, temperature compensating. mechanical tensioner invented by a man named Hoeptner as an engineering school project. In my opinion they were what Porsche should have created. If you don't want them, throw them my way.
Wow...very cool.
Nothing much on the internet about these so thanks for the info! |
similar device as these 2 .Back in the days(1980`s) you gut the old one out and inserted this type...
Ivan http://forums.pelicanparts.com/uploa...1657606835.jpg http://forums.pelicanparts.com/uploa...1657606835.jpg |
I would also be concerned about idler chain sprockets, possibly non bushed, by appearance.
Ivan |
Ivan, you must be an old guy also :cool:
David,,,it was a ramp and roller affair, the piston could always go up, but it couldn't go back down as the roller(s) would wedge against the ramp stopping motion. However as the chain tightened from engine cooldown the entire inner assembly would be forced downward against a spring pressure relaxing pressure against the chain. |
[QUOTE=ed mayo;11741652]Ivan, you must be an old guy also :cool:
well ,old dude i`m it just depend on who is asking;-))))))))working on these beast for 40 years........i did see some funny stuff... one guy drove his 1969 911 to Siberia and back (after shipped to CA)car was so rusty in Russia they welded rail road on bottom of the shasi (each side)to keep it strait.....i did ended up working on it..But the story from the guy was priceless;-) Ivan |
| All times are GMT -8. The time now is 06:18 PM. |
