-   -   How to remove handel trigger 911 '85 (http://forums.pelicanparts.com/porsche-911-technical-forum/1122674-how-remove-handel-trigger-911-85-a.html)
jgurnari 07-12-2022 11:56 AM
going to have handles powder coated... how do I separate the trigger, spring?
thanks
http://forums.pelicanparts.com/uploa...1657652058.jpg
Flat6pac 07-12-2022 04:43 PM
Remove the stud.
Bruce
jgurnari 07-12-2022 04:55 PM
I could not get the stud out, how would you remove it? .. i tried using a pliers but didn’t want to strip it. I was able to slide it off without removing the stud.
Will powder coating with the stud attached be an issue?be an issue?
john walker's workshop 07-12-2022 05:07 PM
Normally there's a captive nut on the stud, so it's been replaced. Tape the stud for painting.
jgurnari 07-12-2022 05:29 PM
The other handle removed didn’t have a stud .. i remember having to loosen 2 nuts. i believe that other stud is still inside the door.
proffighter 07-13-2022 12:51 AM
Just slide the hole thing out, looks like this:
http://forums.pelicanparts.com/uploa...1657698670.png
