Dashman0
Question Upgrade oil pressure restrictors for camshaft
What is the orifice size difference between the standard and upgraded restrictor for the camshaft housings ?
I am thinking about it.
Old 07-10-2022, 02:30 PM
My mechanic prefers upgrading the oil pump.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-10-2022, 02:53 PM
The restricted is about 3/32. I can measure the stock when I get home.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 07-10-2022, 03:07 PM
Depriving the cam and rockers of oil flow doesn't make sense to me.
206 637 4071
Old 07-10-2022, 05:04 PM
Here is a visual of the differences.
Chris
'75 911s Targa
Old 07-10-2022, 06:54 PM
I’m with Walker, I see no up side to the restrictors.
Old 07-11-2022, 08:15 AM
Dashman0
According to Porsche - it decreases foaming of the oil returning to the case. It also increases the oil pressure to all the bearings and squirters providing more lubrication.
It has been suggested to drill the 3/32 (2.5mm) hole out to 5/32 0r 4.5mm
Old 07-11-2022, 11:08 AM
theiceman's Avatar
i have the same micro holes in my bumper pad, what causes that ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-11-2022, 11:39 AM
proporsche's Avatar
yup, this...^^^^^^^....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-11-2022, 01:01 PM
I put them in my 930. Tracked it. Cams looked fine with the exception of 1 that was pitted…
Old 07-11-2022, 01:38 PM
Personally, I would rather replace a cam in a Carrera or 930 than a crankshaft because of oil starvation on #2 or #5 which usually breaks the rod then wipes the inside of the case, oil pump and piston leaving you with a pile of junk.
Bruce
Old 07-11-2022, 01:45 PM
Well if porsche decided it was a bad idea then they might not want to supercede all the previous versions. When trying to get a set of the restrictors I could only find the restricted ones based on the older part number.
Old 07-11-2022, 02:00 PM
I like them in older engines that have lower oil pressure. My rebuilds always get a modified oil pump from Glenn Yee and #4 main groove. there is no need for the restriction because they have plenty of oil pressure. I have seen no harm from running the restricted orfice as is without modification.
Daniel
it's not leaking....it's just marking it's territory
Old 07-11-2022, 05:07 PM
MichaelSJackson's Avatar
So Porsche did this to reduce frothing. The increase in pressure is a side effect. Less frothing helps the oil pump's scavenging.
The smaller restrictors came into use with the 964 pump. So I don't understand the comment about a mechanic rather splitting the case to upgrade the pump instead? Sure the newer pumps are better, but if you upgraded the pump wouldn't you upgrade the restrictors at the same time?
I feel the question is, "Should you retrofit the smaller orifice in an engine with an older style pump?" I'm not aware of any examples of cam damage caused by these restrictors?
Here is an earlier thread with interesting inputs.
Cam Tower Oil Line Restrictors Redux
Michael J
'78 SC w/smaller restrictors
Old 07-12-2022, 08:36 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
I never understood this either. Without the restrictor, is there not enough oil for the bottom end?
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 07-13-2022, 09:19 AM
