-   -   Does anyone in Chicago have a muffler and cat/bypass I can borrow? (http://forums.pelicanparts.com/porsche-911-technical-forum/1123060-does-anyone-chicago-have-muffler-cat-bypass-i-can-borrow.html)
Otter74 07-19-2022 12:20 PM
Diagnosing a problem mentioned in other threads, and I'd like to do an A vs B with the exhaust and swap out the muffler and cat. I have a stock muffler and non-functioning (so I was told by the PO) cat. I have a wideband O2 sensor so I'd need something with a bung in it, but swap pieces don't have to be stock. Simply removing what I've got is going to be so loud as to be useless, most likely.
If anyone in the Chicago area has one or both that I could borrow for a weekend, I'd be most appreciative.
SCadaddle 07-19-2022 06:08 PM
My 82 SC has a stock muffler and a stock cat that has been absolutely gutted. Nothing in it. Still have the O2 sensor installed and it is working fine with the Lamda system set to the proper CO. It's really not much louder.
Otter74 07-20-2022 08:05 AM
I may not have been clear enough - I want to swap to see if my exhaust is contributing to the issue I'm having. I could just remove the exhaust, but then the engine will likely be too loud for me to tell whether the condition has changed. Idle might be OK, I dunno. Current exhaust setup on the car is the same as yours.
Gadsby 07-24-2022 03:33 PM
I have both for you to use in a test. In Barrington.
Otter74 07-24-2022 03:39 PM
@Gadsby - thanks. Friday I noticed a possible leak at a gasket so I'm going to test for that first. If that doesn't show a leak, I'll take you up on it and PM you this week.
