-   -   87 911 Trim Part Number (http://forums.pelicanparts.com/porsche-911-technical-forum/1123346-87-911-trim-part-number.html)
Sdgg91 07-24-2022 03:30 PM
I am having trouble figuring out which part to purchase to replace the rubber door seal. It is worn from getting in and out on both sides and I would like to replace it. See below for what I am referencing.
https://uploads.tapatalk-cdn.com/202...c74a893b7e.jpg
fintstone 07-24-2022 07:52 PM
Appears to be the door seal. Depends on if it is a Targa/cab or coupe.
fintstone 07-24-2022 08:04 PM
If it is indeed the door seal, it should probably be
91153109503 for a coupe
91153109541 for a targa
http://forums.pelicanparts.com/uploa...1658718134.JPG
FA-18C 07-25-2022 07:45 AM
Agree with above - door seal. I installed OEM recently, really easy. You will be closing the door a little more forcefully for a bit, but these are the last seals I will need.
Sdgg91 07-25-2022 08:16 AM
Thanks! It’s a targa, appreciate it!
FA-18C 07-25-2022 11:29 AM
I just bought two coupe seals and trimmed them to tie into my targa seals. Gave me a lot of left over should I ever get any damage.
