Newbie Question - Oil Change
Hi - must I lift all four corners of car to change oil? Can I just lift and support with stands the rear? Is that satisfactory? My floor Jack won’t fit under front end and don’t want to just lift from the side w/out attachment piece that I think I would need. Thank you.
Old 07-29-2022, 12:35 PM
Hi,
Don't need to lift any part of the car, unless your car is touching the ground, at least not for my 1981, 911.
Old 07-29-2022, 12:41 PM
Driver
Noah930's Avatar
You can actually do an oil change without having to use any jack or lift on a 911. It's the easiest car on which I've ever changed oil. It may be a little easier to pull on the breaker bar on the sump drain bolt if the car's in the air, but it's not necessary.
1990 Black 964 C2 Targa
Old 07-29-2022, 01:16 PM
MBAtarga's Avatar
Just prepare for the 8 qts of oil to come rushing out of the oil tank! The crankcase will likely have another 2 or so - and the remainder will be in the oil lines up-stream from the tank. You don't have to worry about those - they are typically ignored.
Mark
'83 SC Targa - since 5/5/2001
Old 07-29-2022, 01:23 PM
Drain Pan 6 gallons
My issue is that my drain “pan” is a big 6 gallon container that’s about 8” tall. So I guess if I went with a smaller 3 gallon pan that would work. Thank you.
MBAtarga's Avatar
I've got a drain pan like this - but cut the top opening fully open. Just don't try to use an 6 or 8 qt pan!
https://www.amazon.com/Hopkins-11838-FloTool-15-Quart-Drain/dp/B000AMGYNA
Mark
Old 07-29-2022, 01:29 PM
RFP RFP is offline
RFP's Avatar
Yea! I did exactly the same thing. It works perfectly.
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 07-29-2022, 01:33 PM
Driver
Noah930's Avatar
You can use a smaller drain pan for the crankcase sump. Usually about 3 quarts or so may come out from that.
In comparison, the oil tank (behind the right rear wheel) will have maybe 8-9 quarts come gushing out. So you need a bigger drain pan for that. But unless your car is significantly lowered, you usually can fit a bigger drain pan under there.
I use two drain pans when doing the 911 oil change.
Old 07-29-2022, 02:01 PM
Thank you
I will get a drain pan more useful for my 81sc vice my 97 F350 😄.
Appreciate the advice. I have about 6” below sump and more than that below tank behind right rear wheel. So now I know and appreciate the link.
C
Old 07-29-2022, 02:08 PM
Now the next question is which oil to use or better yet what's the best oil? lol
Old 07-29-2022, 06:28 PM
Mark Salvetti's Avatar
And definitely cut out the top. My first time I tried a pan like this, and the oil doesn't drain fast enough. Quickly overflows the edges and onto the floor. What a mess.
Mark
1979 911SC Targa
Old 07-29-2022, 07:36 PM
Be careful of the splash zone on the tank, if the oil is warm the initial splash is about 2’ across! 3/4” plug lets a lot out!!!
Wear gloves and prepare to change your long sleeved shirt. And safety glasses.
Old 07-29-2022, 07:52 PM
Yes - It makes a big mess!
I picked up a cheap plastic mortar mixing tray from Home Depot for changing oil on the 911. It holds 12 quarts, is low profile, and fits under the car easily.
Old 07-29-2022, 08:06 PM
Thank you all! I have a large rubber “pad” that I use for these changes (1997 Powerstroke) as that has 14+ quarts and it’s always a mess.
I’ll let you know how it goes.
Again, appreciate the warnings and previous experiences.
Old 07-30-2022, 01:44 PM
