-   -   placement of O2 sensor on 3.0 SC (http://forums.pelicanparts.com/porsche-911-technical-forum/1123603-placement-o2-sensor-3-0-sc.html)
sozaysven 07-28-2022 02:29 PM
I am doing a ITB project on a 3.0 SC with stock crossover exhaust. I want to put an O2 on each bank. What is my best location and method?
MichaelSJackson 07-30-2022 02:29 PM
The later SC model had an O2 sensor. Look at the parts diagram (in the PET) for Porsche's location? I think they only had a single sensor after the collector for the two sides.
I think the stock crossover exhaust is going to choke off the gains from the ITB setup?
'78 SC/w EFI and SSIs
icarp 07-30-2022 05:51 PM
4-6" inches past the three tube collector on each exhaust bank.
15-40* degrees of angle from horizontal , make sure you will be able to remove the exhaust valve cover for each placement .
Not a tough job , just think about placement
Mark it an drill it, then weld in the bung
Ian
sozaysven 07-30-2022 07:46 PM
Thanks Ian. What type of metal am I working with? It looks like stainless in those sections.
