Help no spark!
Well I just finished installing the engine after a top end rebuid. Engine cranks fine but it wont fire up! I'm getting fuel but no spark. I can hear the CD box humming away. Any ideas!?!?!?
Jason F-15 Crew Chief (21 years) '86 944 '71 914 (Sold) '79 911 SC (Sold) |
Only the basics
Check timing, check correct wires on correct plugs. Check
coil wire to dist. Check that connectors are down and tight on plugs. I'd try one thing at a time...no point in doing more if the first thing you try fixes it. Also give you an idea what to check if it happens again.
Impotence...Nature's way of saying "No hard feelings." McDaniel 1974 911 Targa 1995 Toyota Avalon 2004 Toyota Tundra Extended Cab |
Also:
check connection at CD box check connections to coil (properly connected?) check "signal wire" to distributor (tends to break internally, I've been told) Jerry M '78 SC |
Thanks for the replys! I've tried everthing listed! Now I'm leaning to the coil because the CDI is humming away. I did all the voltage tests and everthing is good at the connector at the base of the CDI. But still no spark!!!
Jason,
All the CDI-unit whining signifies is that it has power and the DC-to-DC converter circuit is working ... it doesn't mean the unit is getting a trigger signal, or that the trigger signal is being processed! Did you check for continuity through the 600 Ohm pickup coil at the CDI-unit connector? If it is good ... check for low-level AC signal [less than 1 Volt peak-to-peak] while cranking with DMM set on AC Volts, Hz scale, or oscilloscope ... at the CDI-unit connector terminals #7 & #31d ... as shown in the following diagram:
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 06-03-2003 at 02:22 PM.. |
I did that ck I was getting the correct readings. I'm leaning to the coil because it's cheaper!!!
But it could be the CDI.
reply
hey bud, i have a 70t, had the same problem and it turned out to be the points.
Jason,
That was TWO tests: 1. 600 Ohms +/- 10 % at terminals #7 & #31d 2. 200 mV AC signal at terminals #7 & #31d during cranking or while turning removed distributor by hand The only way to rule out the CDI-unit is to measure the 350 Volt to 460 Volt pulses at terminal 'A' of the coil ... with a scope, while cranking!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Warren,
I didn't do the Ohms ck but I did do the mV ck on the distributor with the distributor removed and with it installed. I did get a slight drop when I was measuring it through the harness compared to when I was going straight off the distributer.
You can use a 600v neon to test for output from CDI to coil
Get from Radio shack (called Tandy in UK) and put a "clamp on" timing light on HT lead from coil to dizzy. That'll prove it real quick. Jeff
'72 911T gone '85 TVR |
